nytehawk
Wow guys, I sure wish I had found this website before starting my garage project nearly three years ago now! A whole forum dedicated to the topic of garage flooring -- have I died and gone to heaven? Hmm...what do you think they use on heaven's garage floors? Okay, I digress...
Anyhow, I ended up using the consumer-grade water-based two part Rustoleum EPOXYShield, in a two-car garage kit purchased at Home Depot for $99 + tax. My total budget for the garage (floor, additional wiring, insulation, drywall, and paint) was around $2,000 or less so I wasn't inclined to start out with a $1500 floor. Figured I would start with something basic and upgrade later if required.
We applied the epoxy in July 2005 and I am thankful to report that it has been impressively durable thus far. Now I don't do a great deal of heavy-duty shop work in the garage but we do park our vehicles in it every night and I have yet to experience any hot tire pickup even though we live in the high desert of southern California with summer temperatures routinely reaching 100+ deg F. Sure, I can tell that the coating is not particularly thick and I have made a couple very tiny chips in it as a result of dropped tools. Fortunately, however, those chips are so small you'd never notice them unless you knew where to look and they don't appear to be spreading at all. I've also scratched it slightly in a few places but again you don't notice the scratches unless you know where to look and the scratches thus far have not caused any peeling. For $100, I'm pretty darn happy with the results! (See pictures below)
There are several factors which I believe contributed to my positive results thus far, and I will list them in hopes the information may be helpful to some of you.
Well, that's what comes to mind at the moment. And just to prove that it is possible to have a decent-looking garage floor for just $100 of epoxy plus painting supplies, here are a few photos:
Weekend 1: first half of floor coated (note uncoated portion at lower right)
Weekend 2: second half coated
The finished garage, approx 1 year later
For more photos of the finished product, see my thread in the Garage Gallery:
http://www.garagejournal.com/forum/showthread.php?t=19544
- We purchased the house new in late April 2005. (Concrete was poured sometime ~Nov 2004, so I knew it was fully cured by the time we moved in. I think Rustoleum says to wait at least 90 days after pouring, but I forget.) Between our late April move-in and late July '05 when I coated the floors, we parked on cardboard that I laid down on the floor to prevent our tires from depositing road oils onto the concrete. I really believe this was a significant factor in helping the epoxy adhere firmly to the floor.
- From watching the construction of our home, I knew that there was a vapor barrier underneath the garage slab and I shouldn't have to worry about hydrostatic pressure (do I remember that term correctly?) causing the epoxy to peel.
- Due to the hot summer temperatures, we (my wife and I) cleaned and prepped the floor the night prior and applied the epoxy early the next morning. I used a combination of a regular thermometer and one of those adhesive fish tank film thermometers to ensure both the air and concrete temperatures were within Rustoleum's specifications before applying the epoxy.
- We applied the epoxy to one half (side) of the garage one weekend, then epoxied the other side the following weekend. (See images below.) This was largely due to items stored in the garage at the time that would fit in half the garage but couldn't be moved elsewhere. I was slightly concerned that the two separate appliciations might appear different or might cause peeling where they met, but that hasn't been the case.
- Just to be safe, I allowed even more time than recommended by Rustoleum before placing items on the newly epoxied floor. However, those warm summer temperatures also ensured the epoxy was thoroughly cured by then.
- Because I wanted to epoxy the floor when it was as new and clean as possible, the remainder of the garage work (wiring, insulation, drywall, paint) was all performed after the floor was epoxied. I may not have done it in that order if I was using contractors, but I knew that my wife and I would be as careful as possible not to damage the floor during the following construction. In the end, their was only one instance of a dropped drywall mud tray that made a small chip in the floor.
- I chose not to use the coloring flecks/chips because I greatly prefer the solid gray look. And although the surface is slick when wet, living in the high desert means that a wet floor only occurs when I feel the urge to mop it.
How do you like your floor jack? Iv'e been looking at that type will it jack up a Pick up?
