LutzTD
Lutz, Florida
We are just finishing up a tech week over on the HAMB and one member submitted this pretty ingenious invention for his old engine stand... If you've done much Flathead For...
I like it, looks a little tippy to me holding from the side though
38Chevy454
Cincinnati, OH
That is how flatheads are held on engine stands, std practice to use the exhaust holes and hold it from the side.
I like the creativity, saw it on the HAMB and thought it was good use of old parts and a cheap HF winch
jayrush13
Lebanon Oregon
KALD, What is the slacker adjuster mod? Keith
You use a slack adjuster off a semi with air brakes. that's how my Dad made his and how i will make mine. I have the adjuster and s cam shaft just need to find a few more pieces.
It has a 9/16 hex on the side that has a spring loaded collar around it. You have to push in and spin at the same time and in rotates the shaft but will hold at any angle. Very heavy duty they replace them on trucks but they still work fine for this purpose. its nice as you can spin them with a speeder or air impact right where you want them. next time i am at my Dads i will snap some pics and do a write up when i make mine
PCO6
Newmarket, Ontario
I've done a lot of MG and Triumph engines from the side and have had no tipping problems, granted they were only 4 & 6 cylinder engines. It makes it a lot easier to work on the front and rear (particularly) of the engines ... which is kind of obvious.
Using a winch and chain on the stand is a great idea.
Falcon67
Merkel, TX
That's a groovy idea for even a conventional engine on a stand.
Vid of a slack adjuster in use - like that even better, less fabrication.
Where do you find those used S-cam shafts? [edit] had to search "s-cam brake" on eBay. All the shafts the same spline and diameter?
DynoDave
That looks slick too. I wish there was a little more detail in the video, as I really don't know what these parts are or what they do (yes, I Googled, and see some for sale, but have never seen/held one of these parts...it's a little hard to understand from that clip.)
Test Tech
Automation Alley
My dad has a very large engine stand that uses a worm gear to drive the rotation. It works great because the worm gear will stop it at any angle. It is large enough to rotate a cat 3306. He uses the engine oil cooler mounts on the side of the motor to attach it to the stand. The nice thing about mounting the motor on the stand sideways is that you can stand the motor nose up, put an eye bolt in the damper pulley hole and lift the crank with a crane. Then, gently swing the crank into place and begin bolting in the mains. This may sound strange to guys who have only worked on small blocks, but lifting a 3306 crank into place by hand is not really doable. If you can pick up and place one by hand, I sure don't want to meet you in a dark alley. :lol_hitti
BWS
Mnts of Va
Looks like it could be pressed into service as a welding positioner....thanks for the brain jog!
Dinorx7
Ok I see how you keep it from spinning in the video (welded pin on the stand) but what actually turns the shaft holding the motor? Is just welded on to the collar of the slack adjuster? Or is there some kind of insert to mate the 2 parts together??
