Kevin54
MEMBER EMERITUS
Urbana, Ohio
Re: Turner\'s Cube
I have a couple of them I made last year. They're setting in the house on a couple of shelves. Everyone that sees them wonder what they are and thing they're cool. I have a formula wrote down somewhere that I can post up. The reason they're called Turner Cubes is that they were something to be made in an apprenticeship programs for Toolmakers. Most are made in a lathe with a 4 jaw chuck. Today, with CNC equipment you can make them fairly quick in a mill or lathe. There are different variations if you do a Google search for "Turners Cube" images. Some are made from cubes of Clear Lexan or other polycarbonate. Some guys have made them where they use a dovetail cutter to undercut the bores and the final bore will drop out a square that is loose but won't come out. Others have made them on a CNC mill where it would leave a round ball in the middle that wouldn't come out. If anyone (machinist) have signed up to the CNC Cookbook, it has a calculator that you can put figures in to make any size Turners Cube with 4 squares in it.
And yes, they are pretty darned cool!!!
Oh,...Ryan, the idea isn't obsolete. Today it seems like there are more and more making them and gaining back in popularity. They're used more in decoration now than as a lathe training project.
metaleltr
Western Ohio
Re: Turner\'s Cube
That is one of the sophomore year projects for the machine trades class at my school. I'm pretty sure they do it on the milling machine.
justanengineer
Motor City
Re: Turner\'s Cube
Did it on a manual lathe at the end of our first semester machine operations course. Its nothing fancy or complicated really, just a form tool.
uniballer
bedford, va
Re: Turner\'s Cube
Couple years ago when I took machine shop, I had to make something like that by hand. Tough!!! No cnc! Class changed in past 10 or 15 years.
Rolleiflex
Austin, Texas
Re: Turner\'s Cube
I haven't seen one of those in years! Again as others have said something from my days in Machinist school.
kazlx
Tustin, CA
Re: Turner\'s Cube
I'm with Steevo. I need to make one. I have looked at them for a while...
PA-Buckeye
central PA
Re: Turner\'s Cube
I took an introduction to machining course at the vo-tech last year for kicks and giggles (but mostly just so I could jump on a real full-sized Bridgeport for some personal projects I wanted to make) and the instructor had everyone get right into milling or lathe work. This was the second milling project he had them do.
flht1997
Buena Vista WI
Re: Turner\'s Cube
My second year high school metals students make a turners cube for a mill project. the first year students make a compressed air engine for a lathe/mill project.
Rye425
CT
Re: Turner\'s Cube
College I did a ball inside a cube. I'd take a pic but there is no way I'm going back to work until next year.
JeffDM
Re: Turner\'s Cube
I think it would be useful to help prove that one knows how to operate a CNC machine. I notice that some of the ones posted are still rigid, some have the inside parts that are free-floating.
neel2008
Mt. Etna, IN
I wish I would have made one of these in my machine trades class....My favorite thing I made was a simple compressed air motor.....then I made a new ultra light weight low resistance cylinder head and bored out and counter sunk the ports and that little guy was FLYING.....teacher came out of his office like wtf is that noise.....then i showed him and he shook his head and went back in his office....kinda wore out the hole in the brass connecting rod with it. lol Then I started working on a sterling engine but never finished it....I should have made a couple of these, maybe also one with the ball in the middle.....oh the things I would make if I had access to a decent mill and lathe again....
03protege
Louisiana
http://www.core77.com/blog/flotspotting/flotspotting_metalworking_master_jake_horsey_24084.asp
Kevin54
MEMBER EMERITUS
Urbana, Ohio
If some are interested, I can get some stock and make a few up, or as soon as I find my print that I have from it, plus the formula, I'll post it up. I'll go in the house in a short and get one of mine, snap a pic, and put of some dimensions.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I don't know whether it was intentional or not, but the one Ryan posted is somewhat off center.
Here is one of two that I made a while back.
STANIMAL
chicago
I am interested assuming its not going to cost the weight of gold .
805gregg
Ojai, Ca
Make something usefull, why waste you time, materials and skills, "there is nothing you can do that can't be done" the Beatles.
Daedalus
I think that's just gravity. The cubes are supposed to be free to rattle around.
In the touristy areas of China you can find similar pieces that are often hand-carved out of jade (or fake jade), often more spherical shaped.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I see that now. I went to the page Ryan showed and there was a larger picture. What threw me was Ryan's pic is sideways, but it all makes sense now and I'll be alright.:tard:
I didn't undercut mine to make them loose. The next ones I may do that.
Scrap Iron
I built one in my machine shop class nothing that resembled a c-n-c in sight. Ahhh the good times. Just a dying bread of real operators due to the all mighty computers.
The Frisco Kid
Central Texas
IN! That's awesome.
