Atomic Rivian Air Hose Reel
If you’re into off-roading, you’ve probably heard whispers about the Apex Compact Reel System. For the uninitiated, it’s essentially a miniaturized air hose reel, meticulously crafted, that lets you have a convenient airline of either 20′ or 30′. A neat little tool to make life easier out in the dirt.
Now, let’s talk about my Rivian. It’s got an onboard compressor—cool, right? But here’s the rub: I’ve barely touched it. Why? The damn hose. It’s stashed away in a bag that lives in one of the gear tunnel doors, and every time I want to use the compressor, I have to fish out this bag and wrestle with the hose. It’s not a huge deal, but stuffing that hose back into its tight little bag is such a royal pain in the ass that I usually don’t even bother.
So, I thought one of these nifty reels might just be the ticket. But this wasn’t just about convenience—I wanted to dive into a project where I handled the design from my lab, while all the fabrication was outsourced to third-party shops. While this idea was percolating, I stumbled across a post on the Rivian Forums. Some guy had mounted his own Compact Reel System to his gear guard ports. I reached out, got the files, and then tweaked them to fit my own needs.
Next step? I sent the “sheet metal” parts off to Send-Cut-Send for cutting, bending, and anodizing. The machined parts went to PCBway for the same treatment. Once everything arrived, it was time to test my measuring and modeling chops—would it all fit together?
To my surprise, it did. The system came together like a charm. Will this lead to me using the compressor more often? Who knows. But that wasn’t really the point. The point was to experiment with this hands-off approach to fabrication—me as the mastermind, them as the muscle.
So, what’s the verdict?
Send-Cut-Send? They’ve never let me down. Their cuts are precise, and the finish is top-notch. This time was no different, and I can’t recommend them enough. PCBway? A pleasant surprise. They took my files, machined the aluminum, and slapped on a sweet anodized finish—all in under two weeks.
In the end, it’s not the same as sweating it out in the shop, making stuff with my own two hands. But there’s still a sense of pride in what I created, and the process was fun—just not quite as fun as doing it all myself.
Continuing education, my friends…
sacrider
I'd love something just like this for my R1T. Amazing work. If you're not planning on commercializing your design, would you be willing to share the files you sent to Send-cut-send and PCBway so I can make one too? If you are, I'd be happy to buy them from you. Many thanks, Jim
danielbuck
hm... in most of my old 4x4s have built in a compressor somewhere in them, and I've never hesitated to use them because of the air hose. Maybe it's a different state of mind in older vehicles than newer ones, I don't know.
R
Ryan
Administrator
Texas/Hawaii
Very nice. What software are you using to produce the design files?
Fusion 360.
Not sure I follow you?
The reason I don’t use mine much is that it was a pain in the *** to put the oem air hose back in it’s fancy pouch… think sleeping bag back in its compression sack type of thing…
CBRacerX
New Hope, PA
Same here.
R
Ryan
Administrator
Texas/Hawaii
Hey fellas... Unfortunately, the guy that created the original files doesn't want me giving out my own that were based on his. To keep the peace, I've honoring that... I guess he plans on commercializing this.
Raymond_B
TX
That looks awesome! I am a big SendCutSend fan as well, most recently I had them make this custom motor plate for my project truck as there's nothing commercially available. 20240830_221146098_iOS.jpg
lukeest
Sweet design! We supply Rivian with some of their tools and components. Now I wanna know if you've managed to go off-roading in yours 😝
R
Ryan
Administrator
Texas/Hawaii
What are your thoughts and opinions on the reel?
I have been debating about getting one for a while.
It's really, really well made... And works fantastic.
Not really... Dirt roads and mild trails, but nothing that anyone would consider real off roading.
Bennylava
Cleburne, TX
Looks bolted down... Isn't it in the way now? Might run into fitment issues when using the bed for cargo. Maybe there is a way to "stealth" or recess it. Sink it into the side and have it swivel out maybe...
Also it looks like it has a hand crank for wind up. Be cool if it had a spring like the shop mounted ones, which would also lend itself more to recessing it.
R
Ryan
Administrator
Texas/Hawaii
I can lock or unlock it in position through the main screen on the dash... or, I can have it lock and unlock with the doors of the truck. I keep it in the bed most of the time, but when I need my full bed, I can just unlock it and throw it into the gear tunnel. It's not an issue at all.
R
Ryan
Administrator
Texas/Hawaii
That's really cool. Are there other points around the vehicle like that?
No... just those ports in the bed. By design, they are meant to lock in this cable:
So basically, you plug one end of the cable into a port, wrap this cable around your payload, and then plug the other end of the cable into the remaining port. It's now locked and tied into the trucks alarm system and security cameras.
I have a tonneau cover, so I haven't used my cable at all... But it's a cool idea for sure.
Bennylava
Cleburne, TX
My only other question would be: Could there be an auto-wind version? So no use of a hand crank to reel it in.
R
Ryan
Administrator
Texas/Hawaii
You could certainly make one... I think it would be an over-complication though. It's only 20' of hose or so... And one of the great things about this is just how small and cute it is.
lund
Nice job in implementation. But that being said, I do not get this. Why spend so much for a tankless compressor that might be used for light blowing off or tire inflation and not much else? This seems to call for a battery powered tool that would be cheaper, portable, compact, etc. Logically that approach also seems more compatible with an electric van too.
