Sears 38 piece set storage
joe_pinehill1
Northern Virginia
Hi, I have an old 38 piece set, the first set I bought and my go to, I can do 90% of jobs with just these tools. The plastic hinges have torn, anyone know a replacement or a recommendation to store set so I can grab and go?
mike93lx
Richmond, VA
My first thought would be something like a pack out with Ernst rails. Or maybe some rails and a soft bag that comes with a cordless tool set.
mike93lx
Richmond, VA
If you want to organize it like you have it, you'll need to source an exact replacement set (unlikely) or so something yourself, like foam in another case
WWheeler
Middleofnowhere USA
Cut what's left of the plastic hinges and cut-to-length a piano hinge and install into the plastic case with tri-fold/folding leg rivets (rivets for attaching to softer materials like plastic)
EDIT: I like Modern Garage's suggestion better for its ease and negligible cost.
J
joe_pinehill1
Northern Virginia
I had the same problem. I went to a HW store and got some small hinges and small screws. I trimmed off the old plastic hinge and screwed the new one on. It works well.
Good idea. Its either that or buy a smaller Packout and Rails. The Packout would add space for more bits and pieces. But also $$.
You can't beat the shadow box/ sponge count of the plastic, I've kept all the sockets together for over 30 years.
driftpin
My solution is like Modern Garage suggested, but I use 1" woven nylon braid or whatever you call it. I usually use pop rivets and reinforcing washers. Sometimes it's the front latches, I used long strap Velcro around the box, and just loosen it a bit, and slide it off one end, and slide it on, and tighten the Velcro when I'm done. I have several blow-molded Sears tool cases I've done these repairs to, and haven't had to re-do any, after years of use.
nbpt100
Massachusetts
Nice work with the long hinge! I have a similar type of cman tool box and love the storage. I totally get your desired to keep it. The hinges on mine are still ok but the two plastic clasps to keep it closed have broken. I now use a bunge wrapped around it to keep it closed. It is not perfect but good enough. I would post a pic but it is in my van right now. Maybe later.
driftpin
Next, I forgot to pick up a small hasp to keep it closed. Or I may try and pop rivet Velcro strips to the front.
There is a 'sexless' Velcro which grips much more-securely than the traditional hook/loop & 'fuzzy-side' Velcro. I use it on a Craftsman blow-molded truck toolbox w/a busted pair of latches. I have it wrapping circumferentially around the box and it does a better job of holding things securely than the pop-rivet idea you have. I considered that, but after trying the sexless Velcro, in my opinion, it worked much more-securely.
On the 1/4" drive small Craftsman blow-molded toolbox sets, when the side of the box hinge pins failed after years of use, I used the threaded moly wall anchors w/the collapsible arms that spread-out as you tighten the machine screw, to provide a new hinge pin. I bet I did that repair > 20 years ago.
rancherbill
Foothills County, Alberta, Canada
No new tools, only bought the hinge.
My rule is that 1/3 of the "saving" on a job is spent on tools for the next job. I have a ton of stuff that I bought this way.
Milwaukee boxes are stupid expensive so I am sure you would have spent $60, so go wild with your new $20 tool budget and take your honey out with the other 40 saving. It's GJ Economics 101
nbpt100
Massachusetts
Those Pack out boxes are marketed to tradesmen working out of their Trucks every day. Organization is key to working efficiently. The cost can pay for itself for someone like that. Not likey worth it to the average person. I am not even considering quality and overall value. Just the concept. It would be a good thread to talk about the different options out there.
Glad you efficiently solved your problem. Everyone looks at how they justify an approach to problem solving differently. For good reasons.
J
joe_pinehill1
Northern Virginia
Agree. I'm devoted to M12 and M18, but as much I try I can't justify a pack-out box set.
rancherbill
How did they ever survive before the Chinese (Milwaukee) solved their problem? There wasn't a problem. They had hand tool boxes and milk crates. Now everybody wants a shiny red plastic toolbox.
Milwaukee Packout are HEAVY and BIG. You put all your stuff in them and you need 2 men and a horse to move them.
nbpt100
Massachusetts
That is why they sell one with wheels and a long handle. Not just Milwaukee but many of them now. Ridgid, DeWalt, Ryobi than I know of. The small parts boxes are a good idea for fasteners, fittings, small tools, etc.
