Odd tools you never heard of that you find browsing online and then want
dscheidt
@JradM: What's the advantage of a froe over other splitting tools?
Mike
The froe has a pretty wide cutting area, which makes them useful for shingles and the like. Also the cutting edge is on the top of the blade, so they have lots of leverage when you get half way through a piece and twist the handle
JradM
Alberta
Mike
What dscheidt said plus you place it on top of the piece you're splitting and whack it with something else - so you hit precisely where you want.
Because it's so wide, you can continue driving it through a log by wacking the protruding end, or pull back on the handle to split something with leverage (and follow the grain).
You're also not swinging the blade part, so it's safer than an axe.
It's intended as a rough, often greenwood working tool, but has a place as an axe alternative too.
The froe is not meant for splitting firewood rounds. It is made for things like shingles, where you want a thin bit split off when you are done. You only get like 1/4" of split with the froe, vs the 2-1/2" of a maul. The control from the handle is great. Not sure what @dscheidt meant by this tho.
Twisting (pulling to one side of the flat blade) will help pop the shingle off. (If you are a real manly man, you might be able to rotationally twist it, but way over my skill set.)
I have 2, one very vintage, one newer. It was recommended to me to use a heavy tree branch or root ball as the whacking tool, as the thin upper edge of the froe if very hard on hammers, wood etc. One of my buddies uses a tree branch about 6" in diameter, turned down to hand sized after about 8".
Also, there is a user made jig called a Froe Break (I think), that contains your stump from wandering as you whack on the froe. I have never made one, or seen one in real life. Saw one in a pic, was a notched stump.
Uncle Bill's Sliver Gripper
They get used ALL THE TIME, especially since I live out in the country where ticks and splinters and such are a normal part of life.
For normal use, these are fantastic. I have a pair in my travel kit, and in my backpack that goes to work. Back when I was woodworking every weekend, I'd spend Monday morning pulling splinters out of my hands.
I have a couple other pairs for more precise work, but these, with a pocket knife to break the skin, will get out 95% of my slivers.
subroc
Dover, NH
Another tool
Microjig Grripper
My carpentry and woodworking is all pretty much self taught. Trough YouTube, forums and some advice from friends and family. Anyway, I bumped into this tool somewhere on-line maybe shopping or a recommendation on a forum, YouTube, somewhere. I am sure I watched the advertising video at the time. I could see the utility in the thing but balked at the price.$60 then, still $60 now...at least today. The more I watched the video on the thing, the more convinced I became. Ended up buying a pair. This is a tool worth having.
subroc
Dover, NH
+1 on these. I use them on just about every rip and dado cut on my table saw. They are also very handy on the router table.
Lee
I use push sticks or push blocks on most table saw cuts. I was using this today cutting some narrow strips and for some reason when I bought the things popped into my head. Some will surely point to the safety of the things as the major selling point or reason to own them and they wouldn't be wrong. But, adding the capability and confidence to make narrow strips is just as strong a reason to own them.
^ You would not use a froe for splitting firewood - that's what axes and mauls are for.
Froes are used for cutting shakes/shingles. Interesting process. After you've blown through two or three shake bolts you get the hang of it.
Don't strike the back edge of the froe with a steel hammer. Find a piece of hardwood and make a mallet. I made my first one out of a piece of pear wood. After it went to pieces Dave made me one out of English Laurel - it's the big one in the photo - too damn pretty to use, though - I found a chunk of Black Locust to use instead.
F-22
I feel so compelled to order a pack of these, but am really struggling to imagine it in use without the swiveling action of the dedicated deburring tool. Anyone have a thought?
I think it would work best if you have a ratcheting bit driver that spins freely in some lever position.
s3zau
The gedore e-8730 I have, the knife swivels in de bit , you only need a good bit retention holder so you don’t pull it out to easy
so it’s working perfect with a fixed holder , even less with a ratchet driver
rslaback
Westcentral Wisconsin
Cool stuff. Do you have a link for the plastic repair kit?
Mike
This is the one I bought according to Amazon. It isn't available anymore but I think all of them are pretty much the same. It shows options on the bottom of the listing page for like products. Mine is an H50 which I believe is the 50 watt option and it has been more than enough heat for my repairs. I'm guessing all the higher wattage ones are specification inflation.
NYBODYMAN
NY
Plug weld pliers:
I want to try out this magnetic version next:
I just grabbed these two from Daggertools.com
and this one for **** welding seams...
https://www.daggertools.com/m5/DT-T...-style-tool-for-sheet-metal-****-welding.html
mikeinri
I have the Vaughn Rage 15" demo tool. Kinda like the FuBar. Works great. I demo'd a room with it.
Wow, I read that too fast. Thought you said: "Wish I had a room to demo with it..."
Mike
mikeinri
Was surfing YouTube (for chainsaw repairs!), and a random video showed up in my feed, featuring how to use this thing...
Extech 40180 Tone Generator and Amplifier Probe Circuit Finder Kit
So, not only do I now want to buy this tool, but the first thing I thought of was this GJ thread!!!
Mike
tak1313
You know how it is, you are looking online and then find something you didn't know existed but you want immediately.
For me, most recently it was these reverse pliers:
For me, it's every time I look online and find something I didn't know existed but want immediately...whether I need it or not...
rslaback
Saw these Noga countersink tools on a Blondihacks video and had to have them. Based on the cost of a single one I had to go with the set of 3 different sizes.
Grokew
Home
However it's too heavy for me so I don't actually use it very often.
First manual ratchet with impact wrench "hooga dooga" sounds. Great for confusing your boss.
For me it was the spin tools Swaging set. It makes installing copper tubing so much easier. No need to use couplings, and reduces the amount of possible leak points.
Spin S6000 6-Piece Drill Bit Swaging Tool Set 1/4, 3/8, 1/2, 5/8, 3/4, 7/8-Inch https://www.amazon.com/dp/B082MPZZSN/?tag=atomicindus08-20
dukefx
The ones with the rotary handles (Facom/USAG, Stanley, Proxxon etc.) have been out for ages and do the same job at the same speed, except they actually last and can be used in tight spaces as well. This is a toy in comparison.
To add to the topic: a little lifting device I'd like to get my hands on that works like a ratcheting clamp but it costs like 200 €. I have a Danish made inflatable cushion that can lift up to 250 kg but it takes forever to inflate. Here it is in action:
F-22
Been waiting to pull the plug on a Proxxon for a while. Such a neat simple solution to the fine tooth count issue.
whitesco
Pittsburgh, PA (ish)
Saw and bought this a while back, LOVE it, both the 1/4 in drive and hex bit drive on the other side:
danski0224
Near Naperville, IL
I could have used one of those Viking Arms the other day.
ex-x-fire
Sheboygan Falls Wi.
A Porta-Vise. I saw one in Popular Mechanics years ago. I'd like to get one.
danski0224
Near Naperville, IL
That Amazon place has them for $205.
Doesn't seem too bad, and the tool is rated for 300 pounds.
I wonder if the euro pricing and dollar pricing is the same number but different currency. Canon seems to do that.
dukefx
The Euro is doing slightly better than the Dollar but they are close. Amazon.de has it for 205 € which is too expensive for my taste.
dukefx
PB Swiss coin driver. I actually use it quite often surprisingly.
I have the stubby version but I rarely ever need it. My pressure washer and my bicycle's tail lamp are the only things I might need it for. It's optional for the pressure washer's oil level cap since I can turn it by hand, but it's easier with the coin driver.
MattGarage
So Cal
Jawhorse. There are a couple knockoffs but I shall have a real one at some point when that annointed one on CL or FB posts it 😎
Tools which I could kick my own **** for not getting earlier:
* Carpenter square
* Combination square
* Nice vernier caliper (fully manual)
* Wobble extensions
* Workmate
