Itsjustdirt
I repaired some plumbing and had to cut a 16”x40ft trench through my asphalt driveway. Is this something I can repair myself? Can I also seal the 50x40 driveway myself if it hasn’t been sealed in decades?
1. I bought a few bags of this to test out. I followed the instructions, tamped it well, drove over it multiple times with plywood, but it still looks very “rough” or open. It looks more like black gravel than the rest of the smooth blacktop. Will it smooth out with time? Is there a better product to use?
2. The quikrete professional blacktop repair instructions say it is only good for confined areas, up to 2’x2’. Technically that means I shouldn’t use it in my 40’ long trench repair. If I can’t use this, what can I use? Any better options?
3. Does anyone have suggestion on what base and how much base to use? I’ve ready anything from simply compacting the soil, to using sand, to pea gravel, to 3/4 gravel. I’ve also heard I should leave room for anywhere between 1”-3” of asphalt repair filler.
4. Any reason I can’t seal the rest of the 40’x50’ driveway myself? Material/method suggestions?
Thank you in advance for any knowledge you can share.
Quikrete 50 lb. Commercial Grade Blacktop Repair Patch 170152 - The Home Depot
Quikrete 50 lb. Commercial Grade Permanent Blacktop Repair Patch is designed to repair potholes and cracks over 1 in. wide in asphalt pavements. Provides superior placement and bonding characteristics
www.homedepot.com
