Why?
bluedog225
Texas
This is the door for the elevator control room in the garage of a houston hospital. I like it but can’t imagine why this door was needed.
It’s not waterproof. There’s a 1/2 gap around the edge.
It would look good on my cabin though. 😂
CoogarXR
Maybe if the elevator comes crashing down (wait- is this at the bottom or the top of the elevator shaft?) it will keep pieces of the elevator car from blowing a normal door off the hinges?
CSRPenFab
Meridian Idaho
Strange that there's a gap. The manufacturer of that door "Presray" makes watertight flood containment doors. I'm thinking the edge seal is inflatable, hence the gauges on the door.
Maybe somebody FUBAR'd the door over the years? I can see them wanting a watertight room to prevent damage to the lift equipment.
LXCam
Inmate/arrestee elevator? Probably a retrofit for a condition that wasn’t anticipated during design and construction.
bluedog225
Texas
The hospital was built after Harvey. I bet it’s just not finished out yet. Typical big organization nonsense.
bluedog225
Texas
There’sa pressure fitting in the door. And a compressor mounted on the wall.
It’s rehab hospital. “Finished” in 2019.
whitesco
Pittsburgh, PA (ish)
I was going to make a wild-**** guess and say a door to contain a sudden release of high-pressure hydrolics or something used by the elevator. But yeah, flood containment makes a lot more sense. :)
ycgoat
S.E. Va
Hopefully there is an interlock to keep the elevator from going down into a flooded space.
PCustoms
VT
Why?
Seems to me that's in a basement, and for the control room. Sealed door keeps the control room dry and let's the elevator run.
bluedog225
Texas
A woman died in Andrew by taking an elevator down into the floodwaters. Rough way to go.
Rusted Nut
Northern Arizona
Hey I forgot to order the machine room door, what do have in stock? Ah..well we've got a door off an old submarine, I'll make you a deal. Sure!
Lassen Forge
If you picture an elevator car in an elevator shaft, as it goes up and down, it (like a hydraulic cylinder and piston) displaces the volume above and below it. The door is designed like that to keep nosey people and ne'er do wells out of the access to the bottom of the elevator shaft but allow the air to vent out of the shaft at the bottom, so the walls don't blow out.
firebirdparts
Kingsport, TN
Inflatable gasket? I think that's the reason you're seeing the gap. Nobody ever inflates it. In fact it looks like you have two inflatable gaskets.
NUTTSGT
Northern Central Ohio
Yes.
The door is swung into place during a flood event. Slide locks are engaged. Are supply is connected to manifold to inflate the perimeter seals, preventing water entry.
Yes.
Notice that one slide lock is slid in place and padlocked to keep the riff raff out in the OP's pictures.
karoc
Hemphill Tx
When downtown flooded (not just downtown) few years ago it was a disaster. The city not wanting a repeat of that, supposedly installed doors to prevent it from happening again.
