110v door jam switch
kinglake
410.16 Luminaires in Clothes Closets.
(A) Luminaire Types Permitted. Only luminaires of the following types shall be permitted in a closet:
(1) Surface-mounted or recessed incandescent or LED luminaires with completely enclosed light sources
A motion sensor bulb usually won't sense the motion with a completely enclosed fixture
I have no idea what version of the NEC that is or how long it has been around, however I can tell you with certainty that the large majority of homes around here, both existing and new builds, do not have have completely enclosed fixtures in closets.
But your point is valid, if the fixture is enclosed you would need an external motion detector next to the fixture. Still probably easier to wire in that a door switch and doesn't involved cutting into the door frame.
Norcal
The NEC has been strict on closet lights for many decades.
gba2331
Although there are lots of switches listed on Amazon, I wouldn’t use any unless they are UL listed or similar, IMO it’s not worth the risk. Just a thought….
