Would you rather... Garage Apt or Bigger House
tez929rr
Welfare, TX
We built a second shop steel building that included an apartment. The taxes are much lower than they would have been for a conventional guest house or an addition to the main house. Other than suspended ceilings the interior of the apartment is indistinguishable from a stick construction home.
u2slow
BC
Bylaws. Check yours.
I can put a substantial addition on my house, legally, but disallowed from making a garage apartment, cottage/cabin, guest-house, etc. Even a shop washroom can't have a shower.
Of course, if you don't ask any authorities, and nobody complains... you can do whatever. :sneaky:
dcg9381
Austin, TX
Bylaws.
Sounds like it could have a sink with an attachable shower head hose (just like my RV) and a floor drain. Sometimes you have to be creative.
I'm a rule follower. Unless the rules are stupid. Telling me what to do with the inside of my home is stupid.
u2slow
BC
Inspection is over so I'll do whatever I want now too.... but there was a fight over having the bathroom rough-in before concrete.
The other bylaw matter was a very tight limit on detached building (interior) square-footage.
67CarGuy
Outside Boston, MA
BTW when doing the plans there is no 'bedroom' in the basement. The room is a study, or a library, or a theater room, or a game room, anything other than a bedroom. That helps w/ septic system requirements and may help w/ taxes but I am not sure of that. Finishing off part of the basement will be less expensive than adding to your shop.
Exactly - if you don't know the rules, you can't play the game (very well).
In our area, any room larger than 70 sq ft that also has a window larger than 3.3 sq ft (roughly 20"x24" opening) is considered a bedroom, unless the doorway is larger than 60" wide, or it opens into a garage, or.... the list goes on. So as pointed out above, if that "bonus room" shown on your hypothetical plans has a 60" wide opening for some nice French doors, then it's not a bedroom. No window? Not a bedroom. Etc.
To answer OP's original question: If I were single, I'd be looking at a barndo-type setup, with large garage below and living space above. Maybe a loft in an old aircraft hanger in some "quiet" corner of an airport... :p
As I am decidedly not single, we're building a bedroom on the first floor for "aging in place" or aging visitors, etc. No steps up from the front door to that bedroom, a curbless shower with blocking for grab bars, doorways wide enough for a wheelchair, etc. Unnecessary? I hope so... But much like our tools, I'd rather have it and not need it than the opposite. YMMV.
dcg9381
Austin, TX
A good GC friend of mine said "if there is no inspection associated with the permit" then you can take great license with building code as long as it doesn't violate the larger fundamental building codes that would likely get tagged on resale inspection. IE, not installing GFI/AFI, stairs with no rails, etc.
Around here "by-laws" indicate a restriction within the local community, not one with the larger building authority (city/county). If it's "inside" pretty hard to tell. I'll take a risk there. But that's just me.
