Ideal bathroom ceiling height
branimal
The ceilings in the bathroom could go up to 115". I'm thinking ~8' is the right height. That way the drywallers can install two sheets in the non-wet areas and not have to make cuts.
More specifically I'd make it 97 1/8". Two sheets of drywall (96"), one sheet on the ceiling (5/8") and a 1/2" gap on the bottom.
Does that sound right?
dougf
Missouri
Higher the better in bathrooms. More volume means things dont get as hot/humid when showering and youll be able to extract that moist air with a good exhaust fan and the mirrors wont fog up as easy...
mike93lx
Richmond, VA
Is this a shop bathroom, powder room, master bath, something else?
I love having 9' ceilings in my house, 10' would be great. But for a shop bathroom, I would very likely do 8' and keep it simple. If this is in a house, match the rest of the ceilings.
branimal
Will you be using Green Board?
It is better for moisture resistance.
I don't think so. I've heard when painting greenboard it gets waxy and is difficult to paint.
Plan is to 5/8 sheetrock the non-wet areas and run the tile line to just below the bottom of the medicine cabinet all around the bathroom. And use 1/2" cement board + red guard in the wet areas. Wet area tile will go 7ft. Maybe 7.5'.
The last two bathrooms I did, I used a grey board 4x8, 1/2" thick for the wet areas. The name is slipping my mind right now. Manufacturer says all you have to do is silicone the corners. I might use that instead of the cement board. Don't know yet.
mike93lx
Richmond, VA
I only used it for one reno, but had a good experience with kerdi board. You can get it in 4x8 sheets and it's so much easier to handle than cement board. Seal the seams and you are done, ready for tile.
I used purple board for the same bathroom and rolled on a coat of thinned mud after taping, scraping all the excess. Took paint really well and was very smooth and consistent (except for my ****** corner finishing)
iadr
Alberta
I had to chuckle at that. You guys know in the dry parts of the world we set the shower to steam up the room and go away until it's ready, right? lol
mike93lx
Richmond, VA
In many dry parts of the world, houses arent built with toothpicks and pressed powder that will rot when it gets damp
beemerphile
Danielsville, GA USA
...That way the drywallers can install two sheets in the non-wet areas and not have to make cuts.
Any competent drywaller can rip a sheet along its length in about three seconds with a knife following the end of a tape measure. They are more likely to ***** about 5/8" rock than about ripping sheets for height. When my house was sheetrocked, the biggest, burliest, meanest-looking hanger of them all walked by me with a sheet, sneered and said "I HATE 5/8 sheetrock". A few minutes later he came by with another sheet and smiled and said "but that's what I'd use if I was building my house."
NUTTSGT
Northern Central Ohio
.... and that's why we ask for a general location in your profile. What might work for one, may not work for the other.
branimal
Any competent drywalled can rip a sheet along its length in about three seconds with a knife following the end of a tape measure. They are more likely to ***** about 5/8" rock than about ripping sheets for height. When my house was sheetrocked, the biggest, burliest, meanest-looking hanger of them all walked by me with a sheet, sneered and said "I HATE 5/8 sheetrock". A few minutes later he came by with another sheet and smiled and said "but that's what I'd use if I was building my house."
^^I meant to say 1/2" sheetrock in the bathroom...
5/8" sheetrock outside the bathrooms.
pbon
Leave the gap at the bottom, use rough filler if desired, and hide it behind baseboard so you don’t have to tape another seam.
Can alternatively do the same with crown moulding at the top. If you like the detail of moulding — my house has it in most rooms.
mike93lx
Richmond, VA
Using crown to cover a gap is hack work.
I've done it too, but it's hack :)
CraigStu
Blacksburg, Va
I will say that the red heat lamp bulb in our MBR shower is a lot more effective at 8ft ceiling than the one downstairs w/ 9ft ceiling.
kwb
PNW
Wait... a residential drywaller that spoke English!?!?!?
When was this 1985?
dogdog
He hates it only because it’s heavier for ceilings otherwise cutting the sheet rock is just as easy for 1/2 or 5/8.
dogdog
EH! man handle a 5/8 for ceiling is lot heavier than 1/2 and I used to be able to carry 2x 5/8 and still having a hard time doing the ceiling. Wall no problem.
pcmeiners
"I used to be able to carry 2x 5/8 and still having a hard time doing the ceiling. Wall no problem."
Same here, not anymore. :)
5/8 for everywhere, taping is easier, better as 5/8 covers up multiple sins from slight wall irregularities. Stuff is a ***** on ceilings.. used to be able to do it alone...definitely not anymore.
