BarrelRoll
I'm starting to look for a set of torque adapters. I do a lot of pump and motor alignments at work and have started torqueing my motor foot bolts for more consistent results each move. Depending on the motor it can be hard to get a socket or crows foot in. A lot of the motors use 9/16" or larger bolts torqued to over 100 ft. lbs. so I really need some 1/2" drive torque adapters along with a set of 3/8" SAE adapters for smaller motors, I don't NEED a set of metric though might grab a set.
So far I've found
Proto 3/8" drive 3/8-7/8" $161.95
Sunex 3/8" drive 1/4"-3/4" $109.95 and 10-19mm $109.95
ARES (amazon) 3/8" drive 5/16"-3/4" $94.99 10-19mm
Disen (amazon) 3/8" drive 3/8"-7/8"
Firstinfo (amazon) 3/8" drive 10-19mm $109.99
Mac 3/8" drive 10mm-19mm $239.99 3/8"-7/8" $214.99
Matco 3/8" drive 1/4"-3/4" $204.95 10-19mm $221.95
Snapon 3/8" drive 12 point 5/16"-3/4" $260 (they also offer a 7/8" not in the kit) 10-16 18-19mm $260 (they offer up to 22mm) 3/8" spline drive 1/4"-3/4" not in a ket, 1/2" drive spline set 9/16-7/8" $429 (15/16" spline avilable) 1/2" drive 12 point individuals 1-1 3/8"
Any opinions on a 3/8" set? Any other options out there for 1/2" drive stuff besides snapon? Also any thoughts on spline drive vs. 12 point?
So far I've found
