turtl631
Looking to build a larger garage. I'm on a city corner lot with an alley and the back yard abutting 2 walls of the garage is 4-5' above grade. Current small garage uses block construction there with stick framing. I want to insulate and heat the new garage with OSB or plywood walls for workshop use. Walls will be 10', and the door side and one other will be pure stick framed. The other two will be half concrete or block. I suppose this is similar to walkout basement construction. Location is Wisconsin so cold is more an issue than heat.
Thoughts on best way to accomplish this? Poured concrete with foam and moisture barrier outside? How best to handle the inside in terms of maximizing space?
