Hammond OK& No-Dust grinders
Steve from Socal
Hutchinson Ks.
I have a couple of these OK grinders and wanted to start a thread for these. If you don't know of these this will be a bit of an intro. My first sight of one of these beasts was as a child, ever since I have wanted one, I now have two.
Hammond of Kalamazoo is a company known more for the "trim-O-saw and their abrasive belt finishing machines. They were and are a machine tool builder in Kalamazoo Michigan. From around WWII to the late 1950's perhaps later they made and sold pedestal grinders. They were similar models with the OK being a standard grinder and the No-Dust having an internal dust collector. They came in three sizes 10"-12" and 14" with one, two or three HP. These were made in the days of a bit of cast iron is good more is better, they tip the scale at 500 to nearly 900 pounds. Like many American machine tool builders in the 1930's-1950's design and styling was a key feature, these have the classic Art Deco/Streamline look to them.
These grinders have a few features that are really nice like the tool rests that are on V-ways. The mass of these imparts a sturdiness and the wheels are mounted to oversize hubs. That all translates to a superb grinder that runs as smooth as a watch. The lighted eye shields on my newer grinder are both bright and very rigidly mounted with a wide viewing area. I have two 14" OK grinders, they are a bit different so the models were not static throughout their life cycle.
While these are all three phase machines with modern inverter technology any of these could be powered in a single phase environment pretty easily. They are not as common in the market as other grinders of the same size but, would be a great addition for someone who has the space and or need for a larger grinder. I use mine to bevel material for welding, finishing welds, sharpening drills and chisels, general grinding etc.
Here are my two grinders, they are not show pieces BUT, they will be getting a bit of attention soon. The green one is a bit older, it has removeable side covers and a larger control cut out. The gray grinder has hinged side covers and a single gang box mounted switch gear. I will add to this thread as these get stripped and painted. The mechanical aspects of these are fine any discrepancy was resolved before the were put in use. They both have dust collection ports and, dust collectors are part of the "system" I have relay switching for dust collectors when they power on.
ClappedOutBport
Nice grinder. I have a similar 12". Anyone know what bearings they use so I can buy some before opening it up?
Jayman17
Seattle, Wa
You might want to bolt those to the floor so they don't walk while using them. :lol_hitti Those are some big boy grinders! Very nice...
ClappedOutBport
That's only a problem with ******, lightweight, out balance Chinese grinders. No vibration on these.
Steve from Socal
Hutchinson Ks.
No wimpy 1/2" wide wheels there! Do your lights dim when you turn one on?
No light dimming, I did have to use step up transformers for the gray one. It was suposed to be a 230/460 volt machine, turns out it is a 550 single voltage motor. I have 600 amp/480 service, the 25HP compressor doesn't even dim the lights!
I should have some pics of the gray, now turning white grinder soon. The weather just wasn't kind to paint/bodywork over the winter.
Steve from Socal
Hutchinson Ks.
It has been fits and starts on my grinder the last few months. The major paint and clean up are done, a few touch ups still in the works. Here it is while I am fitting the shields, they are getting repositioned originally on the wheel housing sides to the front. The wiring is next, all internal with a cover plate on the base below the grinder motor, they cone with a large opening below the motor. This grinder is 550 volt I am using small transformers to boost the voltage from 480. I bought this grinder thinking it was 480, when I got it it worked but lacked power, a bit of inspection and it was a 550 volt only machine.
The sealing of the lower compartment is to reduce the chance of metalic dust from getting on the transformers/electrical items in the base. I will post some pics of the innards when I lift the grinder to seal the base.PXL_20230510_174041005.jpgPXL_20230510_174110371.jpgPXL_20230510_174145371.jpg
