Pint-Sized Abrasive Cabinet
Dave Bonzo
I need some opinions.
I picked up a miniature abrasive cabinet yesterday, and I got a decent deal on it because 1) the exhaust fan motor was dead, and 2) it hadn't had a bath in...ever.
Pictured: It looks upset.
Pictured: I dub thee "Pigpen"
I picked up a replacement motor because the bearings in the present one were entirely dead; the "oil every six months" sticker went unheeded by the prior owner, evidently. I had to partially disassemble the thing to get the motor out, as well, and while I was inside I realized that the hoses inside could probably benefit from replacement (they're extremely stiff) and that led me down a rabbit hole, in which I decided to just clean up and upgrade this thing while I have some of it apart. Thus, I need opinions: given the small size of the cabinet (and the small size of my compressor) what upgrades make sense?
I've been reading threads on the subject, but I've only found one or two about the cabinet in question (Snap-On YA433), and there doesn't seem to be a consensus. Most of the advice and input seems to be directed at larger cabinets with higher-volume air supplies...but I don't have space for that kind of setup, so this is what I have for now. I'm thinking of getting a better piece of glass and a better gun setup, at a minimum. Maybe changing the lights as well. Any input would be helpful.
GeoBruin
Check out the Tacoma quick change glass kit and TP Tools for guns.
I have the Harbor freight benchtop model which can't be much larger than that. I needed one for a small space so I went with it and did lots of upgrades. It works great for small parts.
D
Dave Bonzo
I took a look at TP; I think I need to learn more about guns in general before I select one, though. My abrasive blasting experience thus far has been limited to "stick thing in cabinet, pull trigger, clean 1" of surface, begin swearing." I want to avoid that with this cabinet, if at all possible.
Overall dimensions of the working part of the cabinet are 19" wide, 14.5" deep, and about 15" tall...but the extra-big-*** gun and stiff hoses mean that I can't use that area effectively.
I'll definitely look into the glass; I need to change that regardless, because the pane in place right now is effectively opaque.
