Wooden floor in garage?
SUHRsc
Harrisburg, PA
I recently purchased my first garage. It is a cinderblock building split down the middle. One side is 25x40 and the other is 25x50. The smaller side was built first with a flat roof, then the larger side added along with a peaked roof over the entire garage. The problem is that the larger side was never cemented. It is just a dirt floor. I called a few places and seems it may be rather expensive to have someone come in, dig the dirt out, then put stone and cement in. One person quoted $7500!
Talking with a friend of mine last night, he suggested looking into building the floor out of 2x4's sitting on edge. Apparently some older buildings had floors made this way(not sure if 2x4 or 2x6 or ???)
I was wondering if anyone has done anything like this?
Maybe I am wrong in guessing that this might be cheaper?
If so, how would you support it to keep from flexing/moving? How would you seal it on top. Any other ideas or concerns?
At first I shot down the idea, but then the more I thought about it. It could give a very old fasion look to the garage. Which is what I really would like as I deal with antique vehicles. And just basically enjoy all things old...
I realize the limitations with welding and whatnot. Having the other side of the garage as the actual "work" shop though leaves this to be not quite as much of a problem. This would mostly be used for storage of cars and have shelving built to store various other things. Possibly to be used with machinery sitting on it. Lathes, milling machines, etc.
Thanks alot for any input
Zach
This is the place... under construction of the new half
this is sort of what I was thinking for the floor... (from Ryans main page posting)
Identaltech
Norwalk Iowa
I would save your money and have it paved when you can aford it.
I dont know about storing cars on a wood floor made out of 2x4.
have you priced out wood?
how much cheaper would it be if you dig it out and bring in rock.
just have them pour the concrete.
better yet find a friend who can do it.
all you need is one guy with the knowledge and a bunch of strong backs with everyone else.
frank_c
NE Ohio/Lake Erie's South Shore
i worked in a factory that had wood floors like you describe. used to be the old Hupmobile factory here in Cleveland. not sure what was under the floor, but it was pretty much 2x4's treated with something. oil maybe, they were black in color. you'd drive the towmotor and hear the floor moving. it was kinda cool. i remember the maintenance guys driving around with a box of 2x4's and to do a repair they'd just pull the old piece out and hammer a couple more in.
SUHRsc
Harrisburg, PA
thanks guys....
still undecided... just talking out some ideas..
frank... do you remember how the boards were attached? or just jammed inbetween each other?
spongerich
Monroe, NY
I'd think you would need to auger out footings for some joists to support the floor. Those should go below the frost line (Probably 4' or more in PA) If you just set joists on the dirt you're going to get a lot of movement. I'd also be concerned with rot. A wood floor would be nice... it's definitely less fatiguing than working on concrete.
Aberdale
The company I used to work for had an office in Boston. The office was in an old building that built tanks in WWII. The floor was made of 4"x4"x4" wood blocks stacked on edge with the end grain up. I believe they were just stacked tight with no fasteners. It, too was stained dark. Oil maybe? The sub floor appeared to be concrete.
Dale
spongerich
Monroe, NY
Dale
The old L.A. Times building had those in the basement where the presses were. It's incredibly durable. It's also easy to replace a piece when it gets damaged. Sort of like a giant butcher block.
kmacht
Connecticut
The company I work for has wood floors in some places. It is made up of 2x5 material cut about 2" thick and then placed on its side with the end grain facing up. The blocks are hammered in place and then they spread some type of gule/sealant over them. The stuff is black and almost looks like tar. The reason for wood vs concrete has to do with the parts we work on. They are very heavy and very expensive aircraft jet engine parts. The wood floor provides some cushion if one is accidentaly dropped. There is a major downside though. If one part of the floor gets wet from either rain, a dumped bucket of water, etc it tends to swell up. The area that swells doesn't move but somewhere else in the shop ends up buckling big time. They have to cut out those blocks and lay down new ones in the buckled area. Personally I wouldn't do a a wood floor in a place that works on cars. Even if you are only parking cars there you are still going to track grease and oil all over the wood with your shoes. Wood and oil make a great fire starter. Have you looked at putting down cement pavers instead? You only need a base of sand to place them on. Depending on what you want you can find stuff all the way down to $1 a square foot.
Keith
Call me the Breeze
Sebring Fl
A friend of mine has concrete in the front half ( where cars pull in and out )and the back half he has what appears to be old railroad ties. I questioned him about worrying about catching it on fire. He said he's never had a problem with it. He uses cutting torches, welders, grinders all the time. The only thing he doesn't like about it is rolling around under a car with a creeper, as the floor isn't real smooth, and the wheels get caught between the varying slight heights of the ties. It looks neat, but I myself would rather have concrete
rockchucker
Seattle WA
I would not use Creosote/Arsenic soaked anything to roll around or work on. Stuff is not good for you at all.
When I was in High School the Woodshop had similar Wood Floors to what a few of you are mentioning. There was a huge leak in the roof over the weekend due to a heavy Storm. When I got to class later in the day on Monday the Teacher looked pretty bummed. I asked him what was up and he told me to go into the Shop...Hoooooooly ****! The VERY large 10' or so Belt Sander was tipped over as was the best Band Saw in the shop. The entire Floor in the shop looked like the Ocean. It has swelled soooobad that it was enough force to tip over basically the 2 heaviest machines in the Shop. Amazing to see what happened. Weird to see the Floor undulated in parts up to 3 feet and still intact.
Either or...I would go with Concrete especially if you are working on cars or whatever. A much better surface.
Aberdale
Although a wood floor could provide a unique look, it won't be as durable or as smooth as concrete. From a cost standpoint, I can't imagine a wood floor of any thickness being cheaper than concrete. Perhaps that is why 99.999% of garage floors are concrete . . . .
Dale
frank_c
thanks guys....
they'd just hammer the blocks in, i don't remember a bucket of adhesive or anything. i'd guess the subfloor was relatively level so they'd only "fall" so far.
SUHRsc
Harrisburg, PA
Thanks alot everyone... I guess the more I think about it... I might as well fnd a way to do cement
I will save the wood idea for another day....
thanks alot for all of the input, I really appreciate it
Zach
LegacyIndustrial
deerfield, IL
All the old Ford manufacturing plants had a "wood block" floor in the machine shop.
It's real easy on the knees. If you do it right it's not a bad option and believe it or not, quite strong.
6768rogues
Western NY
Our code requires a nonabsorbent floor. If it is not attached to a dwelling unit, that is not required but some of the code people here have their heads in a dark place and argue for it anyway.
NUTTSGT
Northern Central Ohio
One side of my garage used to be a store (think old service station) and it had a wood floor. One of the previous owners "oiled" the floor to preserve it. His preservative of choice was used motor oil.
Talk about a mess, every time you knelt down to work on something you would have a stain on your jeans. It would take some Shout or Simple Green in the laundry to get it out.
I tried sanding the floor, gummed up the sandpaper. I could scrape part of it off, but still it left some there. I would sweep up the saw dust across the floor and make a couple of passes trying to wear off the oil, but it still never came up. You could tell after 10 years that I was making progress, slowly. I finally ran across a deal on some PT 3/4" plywood and out with the old and in with the new.
This was the old floor, notice the darkness by the door. That's a low traffic area and still has a built of oil on the floor.
A comparision between the old and new.
Finished
Now I realize, the floor that you will be using won't be a regular framed floor but I wanted to advise you of the nastiness of a wood floor. it might work for some but I wouldn't recommend it. I'd suggest stoning the area and saving cash for a future concrete floor.
Ree75
Lincolnville, KS
where I work we have a lot of old ****, and I do mean ****. One of the warehouses (used for carpet)has wood floors, was built in the late 1800's/early 1900's and we drive an old toyota propane forklift over it. Underneath it are 2x10 spaced about 24" apart. those are supported by 6x6 posts about 5 feet apart. Top layer is plywood, normal 3/4" 4x8' sheets, 3 layers deep and overlapped. the worst problem is moisture. the building leaks, the wood gets wet and rots. That forklift probably weighs about 9,000 pounds not including the carpet fork and a full roll of 15 foot width carpet.
This warehouse is a pita. The areas that see only wetness from the wheels of the fork when it rains outside are fine. The areas that get really wet though are a pain. Crossbeams rot, the plywood rots. It's a pain to fix and repair, which includes tearing out partial interlocked sections
daniel999
even I was going to suggest the same thing. Cementing is better than wooden floors as it is strong as well long lasting.
FearTheH
Roanoke VA
This is what the wood block floor everyone keeps mentioning looks like. This is the floor in front of my weld platform, building was constructed in '55 and the entire plant is like this minus the front offices as well as the spot where our new punches, metal brakes and laser are located which is polished concrete. These floors are good for easily running conduit and black iron piping underneath but I surely wouldn't recommend it for a garage, or any wood floor for that matter.
Hawk136439
Illinois
I worked in a manufacturing stting that had some old buildings and some new and the oldest sections still had wood block flooring like that posted by FearTheH. From talking to the folks working there and just my general running around, the wood floor seemed to be a lot nicer on the knees especially if you had to stand on it for 8 hours a day running machines. So for a tool room/ Machine shop/ wood shop it might be nice, but for a garage I would not want to be laying on it or trying to roll jacks and set up jackstands on it.
James-W
Southeastern Wisconsin
A wood floor might look good for showing off cars, but concrete makes a much nicer floor for a working garage. I have a working garage, but I mostly do woodworking rather than wrenching. I have a concrete floor with Racedeck floor tiles and I am VERY happy with them.
Additionally, in my opinion, for showing cars a concrete floor with Racedeck or similar plastic tiles looks really good too. Plus, with plastic floor tiles you can change the colors and the design based upon the vehicles that you have to show.
