Can anyone help me ID/source this seal type?
TT_Vert
Wauconda, IL.
Best I can find is it's an Tee seal but I know there has to be a more common (and easier query-able) trade name or term to try to source the size I need? This sits in the channels of my rv windows to prevent water intrusion.. The channel it sits inis about 5/16" and the top part is ~3/8" but I know there will be tons of sizes, just trying to give guys an idea of scale.
Thanks
Davae
T
TT_Vert
Wauconda, IL.
I put t shaped rubber seal in the search engine and it came up with thousands of hits within a couple seconds. Do the same and select images and click away.
Unfortunately that nets me mostly the cosmetic plastic trim that you put into edges of tables etc, with the slit around the perimeter
48windsor
Olympia ,Wa.
Thanks
Davae
48windsor
Olympia ,Wa.
I used Steelerubber products when I owned my 48 they were great , reasonably priced.
If you have something old they can copy reproduce it. Than someone else can buy it
BillK
Beautiful Southern Maryland
I would think that the easiest place to get it would be the RV manufacturer or dealer. Either that or a glass shop. You will probably go crazy trying to find the exact thing online. I dont see whay everyone is talking about having somebody reproduce it. I will almost guarantee you it is a stock size and should be easy to get.
Just my opinion,
Monza Harry
Windsor ON
Like @BillK said above look at some glass shops, particularly Auto Glass shops, as that looks like some trim I purchased for a project many years ago. The product I purchased was for surface mounted windshield the trim less variety. Harry
