TheLawnRanger
At Harbor Freight, you can get a 5ah battery or two 2.5ah batteries for about $50. Which would you choose?
A milwaukee or dewalt batteryAt Harbor Freight, you can get a 5ah battery or two 2.5ah batteries for about $50. Which would you choose?
Actually, for the grinder, Sawzall, and yard tools a 5.0 isn't really the way to go. Use the newer generation of big dogs: 6.0, 8.0 or 12.0 batteries that use the 21700 cells. The 3.0CP's use these bigger cells as well so the 2.0 and 5.0 are now basically obsolete. I have a shitload of 2.0 and 5.0 batteries but they're several years old now. Anything I currently buy I go with the bigger cells. These examples are for the Milwaukee system.How many tools do you have?
How many batteries do you have now?
Do all your tools have batteries now?
What tools are you trying to power now and what tools are you planning to add to the mix?
A grinder, reciprocating saw, maybe a circular saw, yard tools, a work light used for an extended period of time or a big job with a hammer drill I might want or use a 5a battery. A smaller job with a compact drill or a hand held flashlight for limited use I might choose the 2.5.
Anyway, buy both.
Certainly there are other options. I have mostly Dewalt tools. I didn't comment on them. I was commenting on the choices the OP was considering.Actually, for the grinder, Sawzall, and yard tools a 5.0 isn't really the way to go. Use the newer generation of big dogs: 6.0, 8.0 or 12.0 batteries that use the 2700 cells. The 3.0CP's use these bigger cells as well so the 2.0 and 5.0 are now basically obsolete. I have a shitload of 2.0 and 5.0 batteries but they're several years old now. Anything I currently buy I go with the bigger cells. These examples are for the Milwaukee system.
DeWalt has the identical program. Their 3.0, 4.0 and 6.0 batteries and above use the 21700 cells. You can tell this as the battery packs are wider to accomidate the larger cells.Certainly there are other options. I have mostly Dewalt tools. I didn't comment on them. I was commenting on the choices the OP was considering.
That is all well and good but has little to nothing to do with the OPs question.DeWalt has the identical program. Their 3.0, 4.0 and 6.0 batteries and above use the 2700 cells. You can tell this as the battery packs are wider to accomidate the larger cells.
Knowing now you already have a 2ah i'd get a 5ah.I only have the Hercules brushless impact driver now but plan on getting the hammer drill and ultra impact wrench. So far, the jobs I've done with it were on the light side and the 2ah battery that came with the kit has done well. I'm planning on building a lean-to on my shed this summer which won't be a very big job either.
