Dumb question amnesty required.
Ordered my lights for the shop, 10 primelights USA high bay
PERFORMANCE SPECIFICATION:
Lumens: 25,400
Watts: 164
LPW: 154
Color: 4000k
CRI 83.2
L85 L85 @ > 200,000 hrs
Max Ambient Temp 125° F
Min Ambient Temp -4° F
Dimming 0-10v Dimming to 1%
Driver Voltage 120/277
Chip Samsung B+ S4
Driver D23CC90UNVT-F
Currently the plan is to divide in half. 5 lights on each switch. setting up as a 3 way for the two shop access points is ideal but not an absolute need.
The spec sheet obviously calls for a 0-10v switch, but unclear if I need to be selective about getting the right 0-10v dimmer switch. Would I size the switch based on sum total of the draw of lights on a switch (165 * 5 = 825), or would I pick on the base wattage and assume it's going all around (165 watt)?
Can get a general 0-10v switch, but limited to 450w
If using the sum wattage total approach this would suffice, but obviously makes the the price point a little bit cringey
https://www.larsonelectronics.com/p...tXWkHZk0IMx-OgL1zwh76KPirLfGaD8xoCuogQAvD_BwE
Any feedback, including if i'm an idiot or overthinking this is appreciated.
Lumens: 25,400
Watts: 164
LPW: 154
Color: 4000k
CRI 83.2
Chip Samsung B+ S4
Lutron Diva Dimmer Switch for 0-10V LED/Fluorescent Fixtures, 3.75-Amp, Single-Pole or 3-Way, White (DVSTV-453PH-WH) DVSTV-453PH-WH - The Home Depot
Diva 0-10-Volt dimmer switch is a simple solution designed to match existing decora-style switches and accessories. This Diva dimmer switch is a 0-10-Volt DC Dimmer to control 0-10-Volt LED and Fluorescent
www.homedepot.com
