What do you pour into seldom used floor drains???
atch
Columbia, Missouri
We have a floor drain next to the water heater in case the pressure relief valve pops off. This is in a 23 year old addition. There has never been a water heater issue. We routinely pour a cup or two of water in the drain to prevent sewer gas coming into the house.
Seems like I've heard of pouring something in the drain that doesn't evaporate. Maybe cooking oil? I'd sure like to put something in there one time and forget it.
What is it I'm trying to remember?
Or; what do you use?
b-t-w; we're on septic tank out in the boonies.
housewolf
East Texas
Yeah, you can make sure it’s full of water then pour a tablespoon or two of cooking oil, mineral oil, hell motor oil for that matter. Just something to float on top of the water and keep it from evaporating
imagineer
We have a similar situation, 1/2 bucket of water every two weeks.
My house is essentially 2 full dwellings. A normal house on the main level and an efficiency home in the basement. The prior owner installed a new water heater in what was the old shower stall. It's nice peace of mind knowing if the water heater springs a leak, it's above a floor drain.
FWIW, the water heater (A.O. Smith N.G.) was installed in '97 and is still doing fine. I suspect that since we have high iron in our well water, the water heater tank is in osmatic balance and not deteriorating as quickly as expected.
I have on my phone calendar a reminder for every other week, to check the salt level in the softener and to pour a 1/2 bucket of water down the floor drain at the water heater.
AffableCurmudgeon
Triad Area NC
If you divert part of your softener drain to the water heater drain, you won’t have to worry about one of the two tasks. Provided that the two are in close enough proximity , etc.
Monza Harry
Windsor ON
Is it possible to rout the drain from your furnace (condensate pump on HI Eff. furnace) A/C, or dehumidifier [or other leaking type device] to the drain. Refills this for you. Other wise I'd suggest as someone else said and use RV antifreeze. Harry
gregs
At work we have floor drains in the bathrooms. One of them always smelled and we would pour water down it almost daily. I found a device designed to fit inside the drain under the grate. Its kinda like a one way silicone valve that allows water to flow thru it, but closes tight enough to stop the smell or the evaporation.
A
atch
Columbia, Missouri
There is an unused water softener right there and when I used to use it the water from regeneration went down this drain. Then I got married (18 years ago) and Sherry had me bypass the water softener because she has LOTS of indoor and outdoor plants that she is constantly watering. She doesn't want to water with soft water, so the softener no longer drains into this floor drain. There is the typical 3-valve arrangement whereby you can just bypass the softener any time you want by turning those 3 valves to the opposite of what they are now; water plants; and turn the 3 valves back. She'd rather just do without soft water. And if that's what Sherry wants then that's what I want.
That's a new one on me. Thanx.
gregs
I couldn't find the information on the one I installed years ago but googled "floor drain trap seal" and a bunch of different ones came up. Just have to know your drain size and type. The one I put in was shaped like a funnel so it had a chance to fill with some water and add weight to make it open, I had wondered if the flatter ones might "stick" shut.
As to the water softener, I guess you dont have any non-softened spigots? I am guessing your on a well and there is usually one at it. We have been watering our house plants with the softened water for years without a problem, and anything outside just gets plain well water. The benefits of the softened water are many if you have hard water.
A
atch
Columbia, Missouri
Negatory on the unsoft spigot. We're in the boonies but on a water district. While the water isn't hard enough to cut with a saw it is a bit hard.
While I miss the soft water I'd rather have Sherry happy than to have soft water.
humber2
Downunder
A town near me has a river that carries a lot of sediment.
The locals know it as being “too thick to drink and too thin to plow”.
gahrajmahal
Cincinnati, Ohio
RV antifreeze, it shouldn’t evaporate for a good long time (maybe yearly?) It’s used to winterize the toilet and plumbing systems so they don’t freeze.
Uncle murph
Harford county
You might want to try 8-10 gallons of water on occasion just to verify that it’s capable of doing the job when the time comes.
gekljklefgje
I just realized RV antifreeze is totally different from auto antifreeze. Don't pour regular antifreeze (toxic) down the drain..
