VISE REPAIR 101 all vise repairs, lubricants, sources for parts and the tricks to fix
Roberts210
Missouri
ebay will be your friend. But the swivel bases by themselves are getting pricey. And don't go by what the seller claims it will fit. Go by measurements.
beauly
Looking at the solid base of the 9300 images above, can it have a swivel base attached?
D
drivesitfar
Jesse: Wilton did sell some of their vises without the swivel base so you can mount yours to a bench and use it as is. That said if you’d like a swivel base you might have to search eBay or message member autopts and see if he might have something that fits.
Another option is to build or find or buy a stand and mount the vise to it and then just turn the stand as needed for 360 degree access.
Welcome to GJ snd congrats on finding an older Wilton Bullet in decent shape.
beauly
Hello and thank you, I have sent autopts a note (to his ebay contact) Will also try to find him here. Thanks also for stand idea... interesting... also, I posted over in EXP on slide thread, asking for some hinst about the model (clearly 3") but why no "Chicago" etc on the casting, would like to know what model number and rough year as well... Thank you also for the welcome!
D
drivesitfar
After WWII when Wilton lost its government contract and they made several changes to their vises graphics while in Chicago plant and then eventually moved to Schiller park in I think 1957 if memory serves me correct.
If you don’t have a date on the slide it could have worn off with use or it could have been sold during WWII.
CHRIII
NE TN
I finally got around to making some copper jaw covers for my Reed 2C vise.
I purchased a 2' length of 1" diameter copper pipe. I cut the pipe into two 1' sections. I then cut one of the sections lengthwise with my angle grinder. I spread the pipe open and hammered it flat on a piece of railroad track. I clamped the flattened piece in the vise and marked it for the length of the jaws and the 'tabs' that fit under the jaws. I made the cuts with a hacksaw and bent the tabs. I clamped it in the vise with tabs as tight to the jaws as possible, then gently hammered the cover over the top of the jaw. Then i repeated the process for the other jaw. I labeled the covers for the jaws they were marked and worked for.
I have some ideas for leather jaw covers; I'll post them when I'm done.
This picture shows the underside of the covers.
This picture shows the unused half of the pipe and the flattened section that was not needed.20230212_182751.jpg
lilredex
Toronto
Looks good! Surprized that a 1" section would yield enough material for that job. Assume you annealed it first? Going to do the same for my vises, thanks.
Sawmill7
Iron River Mi
I have a lead screw on a 4" Wilton that has a little bend in it..1/8". What is the best way to try to straighten..heat up with a torch or just press it cold? Thanks for any help with this..Bill
LNKMK8
Overland Park, KS
I hate to make another "looking for a base" post, but I thought I would give it a try. I just picked up a Wilton 1760 Tradesman and would like to find a swivel base and hardware for it. I see they are still available new but wow have they gotten expensive. If someone happens to have one saved from a damaged vise, please send me a message. Thanks.
Low277
Minnesota
I just purchased a Paramo HI Duty No 5. It seems to be in fair condition, I have done some reading here but dont find alot of information. Is there any way to tell what era it was made? 1950S, 70s? I am looking forward to cleaning it up and will get better photos.
Roberts210
Missouri
I need a pair of affordable jaw inserts for a vintage Wilton 3" machinist vise. 7/16ths by 5/16ths by 3". Mounting holes are 2 inches apart. I had previously bought a pair of inserts for a 4" wilton machinist vise from an online place called, Mile-X. The price was right--$49. When I asked if they had 3" inserts, they said yes, $212. That's more than I paid for the vise itself. I don't need fancy, I just need decent jaw inserts. Any ideas? I tried Wilton's website, but their search option is really crummy, and hardly showed any inserts--mostly it showed vises.
02WS6SSZ71
Some questions on a Parker 385. I won't get around to making repairs on this until winter most likely but I want to get the pin out of the swivel jaw and clean it up. I knew there was a problem of sorts with how the dynamic jaw snugged up when I bought the vise, but it was too dirty to really inspect. Advice on how to repair is much appreciated.
1). Is the tapered pin typically cast or were they steel? Some gorilla has put some vise grip teeth marks on the pin at some point which can be filed, but if steel I will add weld to keep the original diameter and fix flaws
2) Is the swivel jaw cast? Any risk of giving it some light heat with say a mapp torch to help fight the tapered pin out
3) thoughts on fixing the vise nut/keyway? Looks like someone probably had something in the jawsIMG_20230425_115450145_HDR.jpgIMG_20230425_115336891.jpgIMG_20230425_115259718.jpgIMG_20230425_115249572.jpgIMG_20230425_115229509_HDR.jpgIMG_20230425_114415748.jpgIMG_20230425_114521854_HDR.jpgIMG_20230425_114908413.jpgIMG_20230425_114940007.jpg with them opened up wide and then hammered down on it. The vise nut moves around quite a bit in the keyway. Is the vise nut likely cast as well? I don't see repairing the vise body/keyway easily unless it were an attempt with epoxy. A longer vise nut (lengthened towards the rear) would keep the end from wanting to rock. I could try to tighten up the fit of the vise nut by welding/brazing depending on what material I'm working with.
This vise will never have a hard life from here on out, but I would like to keep it functional for light duty work, and don't want the problem getting any worse. I appreciate any input.
D
drivesitfar
Nice find on the swivel jaw Parker. At least you still OWN the pin cause more than a few are missing theirs. Lots of good info in this big thread about removing swivel jaw pins and most have best luck pushing them out from below up and out. I don’t have access to all my pics at the moment but maybe someone has a pic of a few ways to remove the pin so you can eventually get the swivel jaw to work like it should.
02WS6SSZ71
Yessir, plan on either driving it out or using a couple bolts to press it out. But curious how people felt about heating that jaw up. In my mind, even if it's cast I should be able to get it pretty darn hot without any harm to help ease the process. And I've got one of those vises where that pin seems to have walked off (prior to my ownership). Yet another project on the long list...
D
drivesitfar
A lot of members use heat to loosen rusted parts but BEE CAREFUL and only tap with light blows. Sometimes kroil or other mixes can seep into small gaps and help too.
A ton of users of these swivel jaw vises never knew that the back jaw swiveled hence some of them actually hammering on the pin too.
If you can not get pin out from below pushing up some guys with welding skills weld nuts to top of pin and wrench it out.
Good luck!!
02WS6SSZ71
3) thoughts on fixing the vise nut/keyway? Looks like someone probably had something in the jawsIMG_20230425_115259718.jpg with them opened up wide and then hammered down on it. The vise nut moves around quite a bit in the keyway. Is the vise nut likely cast as well? I don't see repairing the vise body/keyway easily unless it were an attempt with epoxy. A longer vise nut (lengthened towards the rear) would keep the end from wanting to rock. I could try to tighten up the fit of the vise nut by welding/brazing depending on what material I'm working with.
Got a wild hair, started tearing it apart, got sad news. Someone had apparently tried to beat the pin out of the swivel jaw without clamping it down, broke the pivot for the swivel jaw. Pretty cool system Parker used to pin it in place. Welcoming suggestions on how this can be fixed...
Also of note, the vise nut is certainly cast.
D
drivesitfar
Good to hear you were able to get it apart but sorry to hear/see it’s broken. Thankfully vise will still work as a regular vise and maybe even hold triangle pieces too.
I don’t own a Parker swivel jaw vise so I’ll have to defer to other members to provide pics of a good swivel jaw and maybe a potential fix. I do know that Parker vises were built almost like a rolls Royce with a lot of labor intensive features.
Good luck and it’s still a good find.
Craptain
Tampa Bay FL
If the broken parts still mate up accurately they can be brazed back into one piece. If you don't have the equipment to do it, a local welder should be able to do it easily.
02WS6SSZ71
This was broken before I got my hands on it, so I can't say where the rest of the puzzle went. I'm guessing this is more of a fill and recreate the groove situation. I do have the skills to tig braze with silicon bronze or aluminum. Also seen some people recommending inconel filler, and while I've never messed with it I can't imagine it's toooo far of a stretch from stainless
KMScott
This is a hard repair, I've done one a while ago. Here are pic's on how I fixed mine but the hardest part for me was figuring how to hold the cast swivel jaw. I removed the cast material to the center of the cut radius. Happened to be a nominal radius where I could machine a radius on the plug I made to fit in the swivel jaw. Mine came out nice.
KMScott
Removing the swivel pin from the same swivel jaw Parker. Don't be afraid to heat your swivel jaw. The pin on some Parkers are cast.
02WS6SSZ71
"Mine came out nice...." Understatement of the week. I'm no machinest but last night in my dreams I was thinking cutting flat and bolting on a puck with countersunk bolts might be the best way to tackle this. Then you show me how it's done. Now I just need to pony up for a mill.
Out of curiosity, had you tried a brazing repair before that or was it someone else's work?
Also, if you have time, could you please comment on the vise nut keyway damage I pictured above? Or anyone else who has ideas, I'm all ears. Trying to extend the vise nut further back in the keyway so the back end of the nut isn't at the chipped area is my best thought at the moment.
02WS6SSZ71
A bit of well directed heat with the oxy acetylene and a ball joint press made quick work of the pin. I really like the press you made but I was hoping to keep mine in the best shape possible. Thanks again for taking the time to post all the pics
Firstram
Brilliant work holding! It's amazing how the set up can longer than the repair.
KMScott
The braze was done earlier from the previous owner. Just a note about the groove in the swivel jaw. If the groove does not match the pin diameter and location the swivel jaw will lift up when tightening up on a work piece. Parker used a terrible design and I have seen a few fail like yours and mine.
Just a note about my work. I am a Toolmaker and have been repairing tools, molds and now vises for years. I don't post much here because these repairs take a machine shop and most guys here are not equiped for major breakage. This repair was a fun challenge and I'm posting these pic's for maybe a newer machinist that might needs an idea for this type of repair.
As a matter of fact this same Parker 275 had the same break in the dove tail area except worse. Again this repair is difficult. I machined a pocket and fit inserts from the bottom up with the new dovetails. Most of the work was figuring how to pick up the dovetail's from underneath. I did this by using the dovetail nut backup pin that keeps the nut from backing out. Using trig and a 1/2" pin in the casting dove tail told me where the dovetail was located, flipped the vise over and designed two pockets. The rest was machining the pockets and fitting the steel inserts.
On your repair, one possible fix is to remove 3/16 of material on the nut dovetail on the chipped side and brazing in a 3/16 steel plate longer then the break to support the nut beyond the chipped dovetail. This would keep the nut from lifting, make sure it has a little movement sideways and a little up and down. Another fix is to drill and counterbore a screw hole underneath and tap your nut to tie it down, this would hold the nut tight and not alow a little slop in the dovetail area for miss alignment. Most nuts are a little sloppy to allow for misalignment unless it is a Reed. Good luck.
02WS6SSZ71
Very interesting info regarding breakage due to misalignment of the pin and swivel jaw. I assumed my breakage was from someone else trying to drive out the tapered pin without clamping the jaw to body of the vise, and while that still may be, it sounds like that's not the only option. I kind of appreciated Parkers design because it allows you to remove the swivel jaw even if the tapered pin is stuck in place, but it doesn't give a lot of room for error (and also I'm not a toolmaker so my opinion doesn't mean much).
Another awesome repair on the dovetail. I understand such a repair is way out of my league but I appreciate you showing your work. I have a friend who is a machinist, and I will have him help me with the swivel jaw, but for the sake of time I think brazing and extending the nut with some steel will be more than adequate for the tasks I will be taking on with this vise.
One last request, and only if you have time: could you share some info regarding use of inconel for repairs on cast? Used for sticking steel to cast or filling in imperfections only? Crack repair? Pre/post heat or keep it to small stitches with peening? Not a good option for something that changes temp frequently I presume (ie exhaust manifold)? Large cup/lots of argon? How is the inconel different from using 309L? Less brittle? If this is all trade secrets no problem, I can practice on some old truck drums and figure it out over time. I can't thank you enough for sharing what you already have, and that goes to everyone that has shared advice.
Shiftless
East Bay SFO
Hello everyone. Does anyone know of a Rock Island 571 lead screw for sale anywhere?
Thank you in advance!
Best Regards,
Shawn
Original factory is of course the best, but that part might not be unique. You might find other leadscrews would fit. What is the length, diameter, and thread pitch that you are looking for?
ALLFAST
I bought a No.6 some years back, and it has the exact same text, casting details, and the same t-handle style as mine did.
Be wary of any hairline fractures of the inner support ring ( which mounts between the base and vise body.
In my research at the time, I figured mine was built between 1945 and 1952. This was estimated by searching old forum posts ( Paramo hobbyists, etc and catalogs)
Those are great vises and built like a tank!
Have fun,
Shawn
fishwatcher
I don’t know if this video has been posted on GJ already, but I think Dr Restoration did a really amazing job with this Wilton restore and a lot of tricks are in here that people without fancy tools can employ.
I’ve watched many videos, read lots of threads, and still picked up some ideas I’d like to use in my next restore effort.
fishwatcher
GJ Vise Gurus,
Any tips on touching up a recently or previously restored vise with the same can of original paint is much appreciated. Looking for prep advice, tips and best practices.
I posted this question in another thread on paint here.
Thank you!
