I’ve never done this much I thought they were supposed to go in hard but makes sense nowGlue them in. What I felt comfortable using and what I would suggest others using may be two different things, but they make epoxy specifically for this application
ETA; you must have had to whale on those q-bolts. I’ve set a gazillion of them and don’t recall ever mushrooming the end like that. Did you drill the right size hole?? You probably deformed the sleeve on the way down. In any event, epoxy will still work.
Think it’s just as strong? What do you suggest for getting them outGlue them in. What I felt comfortable using and what I would suggest others using may be two different things, but they make epoxy specifically for this application
Are they blind holes or all the way through the slab?Think it’s just as strong? What do you suggest for getting them out
It’s worth a try to just pull up and maybe use a prybar but DON’T booger up the threads. Cut the mushroom off, take the nut off then stack a bunch of washers or cut a piece of pipe/conduit for spacers. Use the nut to pull them out as far as you can then a prybar after that. It may be easy, it may not but they will eventually come out but the sleeve might stay in the hole. If you through drilled them, just knock them down into the dirtThink it’s just as strong? What do you suggest for getting them out
We do thousands of expansion bolts a year occasionally one or two get screwed up, it happens. The least destructive way is to core drill the bolt out to the next size.I used a cheap but that had a wide head on the top and thought they were going in too loose so ground a little off of the tip and think the expansion sleeves are maybe messed up now in the holes. How do I remove the wedge bolts now
BlindAre they blind holes or all the way through the slab?
Epoxy is very, very strong
Where can you get a core drill bit? Do you need a special drill for that ?We do thousands of expansion bolts a year occasionally one or two get screwed up, it happens. The least destructive way is to core drill the bolt out to the next size.
Do them one at a time.
Had a guy helping me, think he was going to cut a fat hog in the ****.
He drilled all the holes. Blew the holes out. Then put the epoxy in all of the holes.
When he got to putting the anchors in. He couldn't and had to start over.
Wail, and yes, I was thinking the same thing.Glue them in. What I felt comfortable using and what I would suggest others using may be two different things, but they make epoxy specifically for this application
It's a saying. If somebody is going to cut a fat hog in the ***, they are going to make things easier. It is usually used when the plan goes awry.Huh??
