Craftsman, Easco, K-D, Allen, RHFT ratchet kit chart
Draftpick
I have made a list of all the Round Head Fine Tooth(RHFT) ratchets with the knurled speeder on the bottom, and all the repair kits are interchangeable. I have tried a couple and they are the same. Some of the older craftsmans have a through post quick release design, and that is no longer in use, other wise kits are the same, still available from Sears, Danaher. Also some of the older Easco, K-D ratchets were non-quick release(NQR) and if you get a current rebuild then ratchet will now be quick release. I have seen rebuilds from K-D, Allen, Napa on line, if you cannot get a warranty from either Sears or Danaher. If there are other models that I don't have listed let me know, these ratchets have been in production for 40 years so there may be some odd balls out there. Also added a Ridgid, it is sold with a 960 roll groover to operate it, but is an Allen brand clone, and can be bought buy it self online or through Ridgid. Also another Ridgid sold with a 915 is a 1/2 long handle with a 90 degree bend on the end of the handle.
Allen 1/4 model# 10904, repair kit#10908
Armstrong 1/4 model#10-915, repair kit 10-963
Craftsman 1/4 model# 43187,43178, repair kit#43426
Easco 1/4 model#711106, repair kit#10908
K-D 1/4 model#711106, repair kit#10908
Master Mechanic model#T1060(NQR)
Napa 1/4 model# NHT NM-47, repair kit#10908
Allen 3/8 model#11904, repair kit#11908
Armstrong 3/8 model#11-915, repair kit#11-963
Craftsman 3/8 model#43781,42794(Flex),42792(Flex),43788, repair kit#43436
Easco 3/8 model#721109,721413(Flex),721412(Flex), repair kit#11908
K-D 3/8 model#721109,721413(Flex), repair kit#721103(old),11908(new)
Master Mechanic???
Napa 3/8 model# NHT NB-47, repair kit# 11908
Allen 1/2 model#12804,12806(LH), repair kit#12809
Armstrong 1/2 model#12-915, repair kit#12-963
Craftsman 1/2 model#44977.44983(Flex),44944,44973(Flex),44978, repair kit#43446
Easco 1/2 model#731112,731111, 731116(LH), , repair kit#12809
K-D 1/2 model#731111,731116(LH), repair kit#12809
Master Mechanic 1/2 model#T1660, T1661(NQR)
Napa 1/2 model#NHT NS-47, repair kit#12809
Ridgid 1/2 model#70437(LH), 92202 (LH90), repair kit not available from Ridgid, send in for repair.
NQR- non-qiuck release
LH- Long handle non-flex
Flex-Flex handle
LH90- Long handle bent 90 degrees on the end
All other ratchets are quick release, and standard length
billymade
New Mexico
This should go in the STICKIES area! Along with other rebuild kit #'s for other manufacturers like snapon, mac, matco etc...
SnowBlaZeR2
Texas
Does anyone know a good place to start looking for these kits? I have been searching for this 43436 for awhile now with no luck. My Sears didn't have any when I stopped awhile ago, but I didn't really press the issue. Everything I'm finding is outdated and no longer offered. Maybe I'm just terrible at searching...
kythri
Lebanon, OR
Awesome list bro! Thanks for that info.
I have something to add along these lines.
Bought this older Craftsman 1/4" rat last weekend, and it looked like a recent QR Husky I already had. Laying them side by side they looked REALLY close. And the innards interchange!
Both ratchet mechanisms are tighter in the Craftsman, but both work in both rats. I'm told Stanley made C-rats in the early 80's - and they now own Husky.
I'd bet the 3/8 and 1/2 will interchange as well. have another comparison to make soon - will post the results.
That looks like one of the Canadian Craftsman ratchets, made overseas. Had a 1/2" one that spun free, didn't know that it was a Canadian-sold job. Took it back to the store and they replaced it with the bottom-end 1/2" brushed-steel-looking job with a sort-of-tri-wing selector, no quick release. I don't see those around anymore...
sselander
CT
From an old post on the Craftsman board posted by "Adam"
apparently copied from an old chart:
Craftsman Ratchet Rebuild Kit numbers
cCraftsman Ratchet Refurbishing Kits
1/4"
44807 Teardrop-Quick Release 43424
44812 Teardrop-Quick Release Fine Tooth 43424
43187 Round Head-Fine Tooth 43426
43174 Round Head 43425
43186 Teardrop-Quick Release- Obsolete 43427
3/8"
44813 Teardrop-Quick Release-Full Polish 43434
44833 Teardrop-Quick Release-Full Polish-Long 43434
44808 Teardrop-Quick Release-Long 43434
44811 Teardrop-Quick Release 43434
44815 Teardrop-Quick Release-Flex 43434
44834 Teardrop-Quick Release-Flex-Stubby 43434
44835 Teardrop-Quick Release-Flex-Offset 43434
44836 Teardrop-Quick Release-Ergo 43434
44837 Teardrop-Quick Release-Black Oxide 43434
43781 Round Head-Fine Tooth 43436
32794 Round Head-Fine Tooth-Flex 43436
43175 Round Head 43435
43784 Teardrop-Quick Release – Obsolete 43437
44995 Thin Profile teardrop QR ratchet 43438
1/2"
44814 Teardrop-Quick Release-Full Polish 43444
44809 Teardrop-Quick Release 43444
44816 Teardrop-Quick Release-Flex 43444
44838 Teardrop-Quick Release-Black Oxide 43444
44977 Round Head-Fine Tooth 43446
44983 Round Head-Fine Tooth-Flex 43446
43176 Round Head 43445
44985 Teardrop-Quick Release – Obsolete 43447
Obsolete refers to the oil hole in the head model ratchets.
sselander
CT
Maybe a kit for Armstrong ratchets would fit some of the Cmans?
The list comes from the current Armstrong catalog
1/4” Drive Armstrong Ratchet Repair Kit
Product Number 10-990
Contains the following parts, with illustrated instruction sheet, for
repairing the 10-972 and 18-972 Armstrong Ratchets: Gear, Pawl, Shifting
Lever, Spring, Ball, Cover Plate, 2 Cover Plate Screws. In cardboard
box. Approximate weight, 0.07 pounds.
Product Number 10-963
repairing the 10-915 Armstrong Ratchet: Reversing Lever Plate, Retaining
Spring, Gear Unit.
1/4” Drive Armstrong Maxx Ratchet Repair Kit
Product Number 10-982
repairing the 10-992 and 10-994 Armstrong Ratchets: Gear, Pawl, Shifting
Lever, Spring, Retaining Plate and Rings, Pusher, and 2 O-Rings.
1/4” Drive Indexible Armstrong Ratchet Repair Kit
Product Number 10-983
repairing the 10-996 Armstrong Ratchet: Square Drive, Heart-shaped Spring,
Reversing Cap, Central Screw, and Armstrong Ratchet Lube.
3/8" Armstrong Ratchet Repair Kit
Product Number 11-990
repairing the 11-972, 11-973, 11-978, 11-979 or 19-972 Armstrong Ratchets:
Gear, Pawl, Shifting Lever, Spring, Ball, Cover Plate, 2 Cover Plate
Screws. In cardboard box. Approximate weight, 0.13 pounds.
Product Number 11-991
repairing the 11-974 Flex Head Armstrong Ratchet: Gear, Pawl, Shifting Lever,
Spring, Ball, Cover Plate, 2 Cover Plate Screws, Groove Pin, Spring
Washer. In cardboard box. Approximate weight, 0.16 pounds.
Product Number 11-963
repairing the 11-915 Armstrong Ratchet: Reversing Lever Plate, Retaining
Spring Gear Unit.
3/8" Armstrong Maxx Ratchet Repair Kit
Product Number 11-982
repairing the 11-992 and 11-994 Armstrong Ratchets: Gear, Pawl, Shifting
Lever, Spring, Retaining Plate and Rings, and 2 O-Rings.
3/8" Indexible Armstrong Ratchet Repair Kit
Product Number 11-983
repairing the 11-996 Armstrong Ratchet: Square Drive, Heart-Shaped Spring,
1/2" Drive Armstrong Ratchet Repair Kit
Product Number 20-966
Contains the following parts, with instructions, for repairing 12-907
Armstrong Ratchet: Gear, 2 Springs, Shifting Lever, Shifter, 2 Pawls, Face Plate, 2
Plate Screws, and 2 Lock Washers. In plastic bag. Approximate weight,
0.28 Ibs.
Product Number 12-990
repairing the 12-972, 12-973 or 20-972 Armstrong Ratchets: Gear, Pawl, Shifting
box. Approximate weight, 0.31 pounds.
Product Number 12-991
repairing the 12-974 Flex Head Armstrong Ratchet: Gear, Pawl, Shifting Lever,
1/2" Drive Round Head Armstrong Ratchet Repair Kit
Product Number 12-963
Contains the following parts, with instruction sheet, for repairing 12-
915 Armstrong Ratchet: Reversing Lever Plate, Retaining Spring, Gear Unit.
1/2" Drive Armstrong Maxx Ratchet Repair Kit
Product Number 12-982
992 and 12-994 Armstrong Ratchets: Gear, Pawl, Shifting Lever, Spring, Retaining
1/2" Drive Indexible Armstrong Ratchet Repair Kit
Product Number 12-983
Contains the following parts, with instructions, for repairing 12-996
Armstrong Ratchet: Square Drive, Heart-Shaped Spring, Reversing Cap, Central
Screw and Armstrong Ratchet Lube.
bonneyman
Desert SW
This thread is getting awesome!
Now, if I could just figure out how to post a copy of the S-K rebuild kit list I've got?:headscrat
sselander
CT
the other Sears catalog (Sears Industrial) lists these ratchet repair kits as well :)
9-43425 1/4" Ratchet Repair Kit
9-43426 1/4" Ratchet Repair Kit
9-43424 1/4" Ratchet Repair Kit
9-43427 1/4" Ratchet Repair Kit
9-43435 3/8" Ratchet Repair Kit
9-43436 3/8" Ratchet Repair Kit
9-43434 3/8" Ratchet Repair Kit
9-43437 3/8" Ratchet Repair Kit
9-43445 1/2" Ratchet Repair Kit
9-43444 1/2" Ratchet Repair Kit
9-43447 1/2" Ratchet Repair Kit
9-43446 1/2" Ratchet Repair Kit
http://www.commercial.sears.com/comsale/industrial/toolcat/toolcat.htm
sselander
CT
Here is one lookup for a ratchet, preface the Cman kit number with a 9- to lookup the kit
This is for the 43444 kit, for the 3/8" teardrop ratchet:
Craftsman
New mechanisms to renew ratchets.
9-43444--Wt. 0.3 lbs.--Price $2.96
Items within this category Part No. Manufacturer Weight Price For Craft. Ratchets
9-43444 Craftsman 0.3 lbs. $ 2.96 9-44809, 9-44814, 9-44816, 9-44838
9-43445 Craftsman 0.4 lbs. $ 5.08 9-43176, 9-44595, 9-44597
9-43446 Craftsman 0.4 lbs. $ 1.99 9-44944, 9-44973, 9-44977, 9-44978
9-43447 Craftsman 0.4 lbs. $ 2.79 9-44974, 9-44978
easy!
http://www.commercial.sears.com/comsale/industrial/toolcat/ti.cgi/itemsrch.ti/?tool=9-43444
SnowBlaZeR2
Texas
Schurkey
StillTooManyHobbies
Port Tobacco, MD
Add Wilde to the list of companies that used the RHFT 1/4" and 3/8 action. They used Danaher RHFT ratchets in their 12000, 12001 and 12004 socket sets. The ratchets and socket sets pop up on ebay from time to time.
