Can you identify this punch (?)
geomagno
Indy
Was in some of my granddad's things. Tip is very sharp. The blunt end is machined and not a separate piece screwed into place. You can see vague marks on that blunt end where a screw held it into a handle or attachment. There are no holes in it. I've had guesses from plumb bob to leather punch. I lean toward leather punch; if there was a removable handle on the end then I would think this was part of a set. Ever seen this?
G
geomagno
Indy
If it had a handle it could be used as a marlin spike. Was grandad a mariner?
Tip is really sharp. Sharper than marlin spikes I've handled. Granddad was a machinist if that helps.
I would doubt leather. If you were making a hole that big, you would use an arch punch, or similar, as seen here.
Tip is fine, would create a small hole. I suppose it could be used to make holes in gaskets but holes would be imperfect.
G
geomagno
Indy
I think it is a fid for splicing rope
Don't fids have a cavity to hold a loose end to pull through?
If the tip were rounded, most of the suggestions would fit and I could just let this go. Damn it's a quandary. Keep the guesses coming! Any pics of similar tools also appreciated.
G
geomagno
Indy
The fat end shows no sign of any type of impact from a hammer. It resembles a plumb bob in most ways.
The sharp tip along with it lacking a hole to tie a line too makes those I've talked with discount this idea (that was the first suggestion). Aren't plumb bobs short and stubby? I have a couple old school ones. Thx for the input.
G
geomagno
Indy
Already tried to do a reverse image search. Anything similar is short and stubby. Contacted 'tinesdirect' and they had nothing to match it to.
larry_g
oregon
To me the two half circle marks on the small end say 'setscrew' tip to me. So there was something there that was held on by a setscrew.
lg
no neat sig line
SquirrelsTools
Flint Michigan
It looks like the spike my grandfather used to repair wire bridge cable by hand but smaller. Going with steel cable Marlin spike for my guess.
