resurfacing counter tops
indyjps
Oswego ILL
trying to help some friends out with a kitchen remodel. their budget is limited new counter tops arent in the plans for a few years. anyone have suggestions on resurfacing them. the counter tops are in very good shape just 70's orange colored. i have done 2 bathtubs with sherman williams resurfacing products, one in my old home sprayed and the other @ their house brushed and both turned out very nice, the brush marks actually flowed out well. I was considering trying this out on their counter tops not sure if it will eat them up or not will test. also considered just tiling over them after prepping the surface.
any other suggestions on an epoxy type sealer/resurfacer that is suitable for countertops. thanks
Jay H 237
Torrington, CT
You could just get some Avacodo appliances and brown paneling and make the counter tops go along with the decore. :bounce:
I'm guessing the counters are formica. If it's still solid (not lifting or loose) you could rough up the surface and install new formica on top of it with the formica contact cement.
dboat
Dallas, Tx
+1
REFLEXX
Riverside, CA
look into a DIY concrete countertop. you total costs might be cheaper than saving your existing ones.
A friend of mine took a class and said it was insanely easy to do.
poci1957
Decatur IL
I was at a car show last summer and visited a display of countertops/cabinets/modular floors and noticed they used regular formica countertops sprayed with black spray-in bedliner material. I thought this seemed like a great DIY idea as the bedliner material is very durable and would add strength to the coutertop and be resistant to any chemical or scratching. The possible downside I see is the irregular surface, which may be hard to keep clean. I do not recall the name of the company, one could do a web search if interested. Todd C
I
indyjps
Oswego ILL
i just sprayed in a bedliner and the though crossed my mind, this would definately be great in a garage or shop, thought about recovering with new formica but it has the curved lip on the front, also that would require me to do the entire job as they are "construction challenged". im thinking they could brush on the bathtub epoxy themselves, the tile would require lifting the sink etc. bottom line is im trying to assist them and not remodel their kitchen for them, they were getting ready to buy kilz and paint them. i cringe when i see a poor repair/remodel, id rather see orange counter tops than some crappy scratched up paint job. im waiting for my sherwin williams store to open and talk to them about the bathtub epoxy and make sure it wont lift or melt the formica.
there is a comapany called napco that sells supplies specifically for bathtubs and countertops that looks interesting also. thanks again.
ZRWON
Whidbey Island, WA
indyjps said:
trying to help some friends out with a kitchen remodel. their budget is limited new counter tops arent in the plans for a few years... ... any other suggestions on an epoxy type sealer/resurfacer that is suitable for countertops. thanks
Ever consider just installing a more desirable color/pattern of Formica right over the existing top? I must have been told by a dozen experte who ALL wanted to remove our old counter tops and install totally new ones. They said that you couldn't install new Formica directly over old. I went to the Formica web site and got a phone # for product tech support. They told me it was OK (and is ofter done) to install new over old. Did it and 5 years have passed...no problems.
Also rejected the wisdom of other expert installers who wanted to remove my old kitchen counter tops to install granite. Got granite tiles and put the mud board on the old formica counter and pasted down the granite tiles. Saved over a $1000
thump186
maine
I 3rd the new formica or tile. Keep in mind that any product that is used on a kitchen counter will come in contact with food. With that in mind you need to keep in mind it needs to be non toxic and easy to clean so no food residue or bacteria is left around.
DynoDave
This is a great idea for the shop. I'll have to try and keep that in mind.
diygal
SC
would you be so kind as to explain how to install the formica over existing formica...since you were successful, I would love to know the steps you took.
Thank you in advance, for your reply.
lamywaby
any other suggestions on an epoxy type sealer/resurfacer that is suitable for countertops. thanks There are several options for resurfacing countertops on a budget. One option is to use a countertop refinishing kit, which typically includes a bonding primer, decorative chips, and a topcoat. These kits are available in a variety of colors and can be found at home improvement stores. Another option is to use an epoxy coating, which can provide a durable, long-lasting finish. However, it's important to note that epoxy coatings can be difficult to apply and may require professional installation. Tiling over the existing countertops is another option, but it's important to ensure that the surface is properly prepped and that the tiles are securely adhered to the existing surface countertop resurfacing dallas. Before attempting any DIY countertop resurfacing project, it's important to thoroughly research the product and follow all manufacturer instructions to ensure a successful outcome.
There are several options for resurfacing countertops on a budget. One option is to use a countertop refinishing kit, which typically includes a bonding primer, decorative chips, and a topcoat. These kits are available in a variety of colors and can be found at home improvement stores. Another option is to use an epoxy coating, which can provide a durable, long-lasting finish. However, it's important to note that epoxy coatings can be difficult to apply and may require professional installation. Tiling over the existing countertops is another option, but it's important to ensure that the surface is properly prepped and that the tiles are securely adhered to the existing surface. Before attempting any DIY countertop resurfacing project, it's important to thoroughly research the product and follow all manufacturer instructions to ensure a successful outcome.
nateo
Embrun, ON
My in-laws did the refinishing kit a few years back and it looks nice and is holding up reasonably well. Definitely a cheap solution to change the colour. When we bought our house we added an island and replaced the countertops to match, getting rid of the early 00's purplish monstrosity that was there. We stayed with the laminate tops because I'm cheap and we figured we were in for a couple decades of kids abusing them. So far so good!
rlitman
Long Island
Guys, you're replying to someone who was looking for help back in 2005! If he hasn't figured out what he needs by now, I don't think he ever will.
