tool idea - is this viable?
vavet
Ashland, VA
18V battery powered tools are popular.
Portable battery packs are popular for jump starting vehicles with dead/depleted batteries.
What would it take to use an 18V power tool battery as a vehicle jump starter? I'm imaging a slide-on or slide-over adapter with some alligator clip leads. I think the voltage would have to be stepped down to be compatible with a typical vehicle 12V system.
What's the right size battery to jump start a typical 4 cylinder or 6 cylinder gasoline powered vehicle? Let's assume the vehicle battery isn't completely dead, but just a little too weak to do everything it needs to do.
ItsNemo
Canada
How many amps does a power tool battery produce? I am going to guess nowhere near enough to boost a car.
As far as I can tell, the typical Dewalt 5ah is good for ~50 amps peak draw...that's at 18-20v though. A pair of them and stepped down, you might be able to get close to 120 amps, which should be enough to start a vehicle with a weak battery.
I can't imagine those lithium jump packs are anything more than 18650 or 21700 cells in the end anyway and they're not delivering 1000 amps either.
K13
St. Albert, AB Canada
All the ones I see say they are rated at at least 600Amps. Why would anyone want to carry around 2 separate batteries plus some sort of device to convert them into a jump pack when I can buy a dedicated unit that will more than likely outperform it for $130 CDN.
ItsNemo
Canada
There's no way they deliver 600 amps for more than a couple milliseconds though.
I can understand the desire though, I keep tons of cordless tool batteries around and charged and know they'll still work after a few years. Seems most jump packs only last a few years themselves before the entire thing is trash. For a quick jump start of a neighbour or car out in the back 40, I could totally see something like this being handy.
My solution has just been a plug in charger with "starter" function, it's only 100 amps for starter but works every time.
