Bel Aire QP compressor
vette
Does any one have any dealing with the so called quiet compressors?
Are they realy that much quieter or is it just like there regular one with just a box build onto it? There is a rather large price diff. I'm considering the 7hp for my new shop and will be standing only a few feet away.
V
vette
Thanks that helped. Bel Aire states there QP series runs at 69db and I didn't know exactly how loud that was.Seems like it would be quiet enough, guess I'll have to spring for the extra bucks.
rodm1
It would be like a loud PC or vacuum cleaner. All they are is a enclosure covering the mechanicals. I personally wouldn't spend the extra money and make a vented closet around it.
montecarlo31
Yes that's a huge cut from the regular units you see on the market. I'd get one if I didn't have mine mounted behind the house.
where are you located? we're a Belaire dealer and I've personally got a belaire behind my garage that is kick @ss compared to my old crapsman.
purpony
Columbia, CT
we have a quincy t5 here at work and i cant get over how quiet it is! I plan on getting a quincy for home very shortly.
impulse922
SA, TX
any of the compressors with a 1750rpm motor will be quiet, so which ever one of those fits in your budget should be fine +/- 5db
V
vette
Thanks for your reply impulse.It's hard to find the rpm listing on some comp. as they don't show them all. I did find a listing on some Champion ones 5hp at 805rpm's and 7.5hp at 1035 rpm's but no db's listing.There cost is like half of the Belaire QP but I wonder how they compare?
impulse922
SA, TX
look into these...
http://www.eatoncompressor.com/catalog/item/504747/1710568.htm
motor rpm and compressor rpm are two different things.. your quieter compressors will generally have 1750 rpm electric motors and <750 rpm @ the compressor.
quincys and eatons seem to be the forum favorites if that means anything.
V
vette
Thanks again impulse! I was not not aware of the diff. in the rpm rateing and those eatons look nice for half the price! Over a $1000 and only 5db diff. I could build a small wall around it if need be . I quess i"ll be calling them to see about shiping now. Thanks again.
