midnightcruise
I picked up a Prentiss No 56 vise last weekend. It has had a hard life... not as a vise, but as an anvil. It looks like it was used very little as a vise. The screw, and jaws are in great shape, but the beam was cracked half the length. It was so bad that the gap of the crack was just over 3/4" at the end.
I did not take any original pics (wish I would have). But here are the original pics from the add:
So far I have:
- Pulled it apart, cleaned it with oven cleaner and break parts cleaner.
- Preheated, welded, and slowly cooled the beam best as I could.
- Started electrolysis on the handle.
The handle is rusted up and I'm not sure if painting it would hold up to use. Should I try an polish it back to silver and protect it with some Flitz metal polish/protector? or is painting it the correct thing to do?
The beam is repaired and slides nicely with tight tolerance, but there is still some sag from all the years of beating on it. I was thinking about using the highest grit flap wheel and just cleaning it up... unless someone has a way to fill in the sag?
The top of the body has also been used as an anvil. I am thinking just flap wheel it to reduce the look of the abuse. Any other suggestions?
I am planning on painting it black with yellow lettering. There are many suggestions about paint already on the forum, but opinions are welcome.
Thank you for any input.
- mike
So far I have:
- mike
