Agreed re the dry bearings. Not difficult to replace.Bearings are dry. New sealed Electric Motor Quality EMQ bearings would be a good improvement.
Help me to understand how dry (under-lubricated) bearings would allow the grinder to spin for a longer period of time, as opposed to bearings that are properly lubricated. Dry bearings should produce MORE friction, thus a shorter spin-down time, not longer.Agreed re the dry bearings. Not difficult to replace.
Me, too. I guess I've been wrong all of my life.I always took that to mean that the bearings were really good.
Well said.Dry bearings have little lube, or old dry lube. That means little resistance and a long spin-down time. Sure, if you have a new imported grinder and compare it with a new Baldor, the Baldor would probably have a longer spin-down time. But after 20 years of good use, the spin-down time for both machines will almost certainly increase significantly. I say this based on dozens of machine restorations, which I'm sure that many others have under their belts as well.
As to "replacing perfectly good spinning bearings," what I find more often than not, when I remove the bearings from a shaft, is a lot of grit, crunchiness, and perhaps brinneling that wasn't apparent when the machine was assembled, even when turned by hand.
So, test it and find out. Time your spin-down on an old, well-used machine, replace the bearings, and see what you think after you do that.
When I get a new-to-me machine, I usually tear it down and examine the bearings by hand. If the bearings are high quality and seem silky smooth, shields or seals get removed, the bearings get re-lubed, and the old bearings get to stay. If they have any crunchiness at all, I replace them. Why not get it done while in there? That's my take anyway.
Very nice grinder! I believe that 3/4 hp grinder model 397.19670 first became available in 1969. So, it could be as old as 54 years old.I was in need of a bench grinder and this one came along for nothing. Seems to run really smooth. Only thing I don't like is when shut off the wheels spin for a long time. Anyone with experience with this model?
If you are good with getting new bearings, you can always see if you can gently pry away the shields to regrease. If it doesn't work out, nothing lost. Accurate Bearing is a good resource for bearings, if you don't have a local supply house that you like. I think that you'll enjoy that grinder.Bearings are definitely dry. Can hear them when they are spinning. I assume there is no way to grease these. I'll see if I can order some.
$20.00 bucks is basically free these days!Free is always nice, I picked up a 397.1949 recently for twenty bucks. There is a 397 on eBay for $400+. Haven't gotten around to going through mine yet, but is should clean up nice. Thinking of putting maybe a wire wheel on one side and a buffer wheel on the other. Did you know the bottom should have the date? See my last picture.
Also if you are missing any of the rubber feet Hillman 8846 grommets from Lowes should work perfectly. Credit to the gentleman from this post on VM http://www.vintagemachinery.org/photoindex/detail.aspx?id=39402
So I'm attempting the cheap route and I used my finger and slowly pressed grease into the bearing along the top of the shield. It was def allowing the grease in as you could feel the difference. Got it back together and it still free spins when shut down but it slows much faster than before. Nice and quiet and smooth. Its not going to see any heavy lifting at this point. Probably put a wire wheel on one side which will be my main use for it. Worse comes to worse I'll replace the bearings. The whole thing comes apart pretty easy.If you are good with getting new bearings, you can always see if you can gently pry away the shields to regrease. If it doesn't work out, nothing lost. Accurate Bearing is a good resource for bearings, if you don't have a local supply house that you like. I think that you'll enjoy that grinder.
