KnurledNut
Have you posted any pics of your small toolbox setup?I have a small top box, though...
It would be interesting to see what you decided to keep and how its organized.
The plugs in my truck are 18 years old. I contrmplated ordering 16 new plugs for it a few days ago, but couldn decide if I should order the $1.73/ plug copper- nickel like the Oem Mopar plugs, and then have to change them in another 18 years when I’m 89, or spring for the $3.68 / plug platinum plugs that last three times as long and have to change them when I’m 125.I love those, too. Time was, that was what you had, because the spark plugs all were that size. Well, unless you worked on some really, really old cars with even bigger spark plug hex sizes. That changed, though, over time, so you added the new sizes as needed. But, you didn't really change spark plugs so much anymore. Heck, I can't even see the plugs in either of my cars. I know where they are, but they're not going to need to be changed for years.
On the other hand, other equipment with spark plugs need more frequent service. Some have 13/16" plugs. Some have 5/8" or 16mm plugs. I haven't encountered many other sizes since I'm not working in a shop any longer. I still have the sockets, though, but almost no duplicates.
Exactly why I prefer my 14/16mm spark plug sockets.5/8 is 15.875mm.
(.6250 vs .6299)
They are not the same, but typically close enough for use on a fastener head.
Yes, im being THAT guy...![]()
Subaru, Toyota/Lexus. Only thing that matters in my world.What uses 14mm?
16mm?
Unfortuntely too long for Subarus!
16mm only5/8 is the size I find myself needing the most. I’ve never seen a spark plug socket just simply labeled 16mm.
You got the wrong guy. No sharks in Lake Eire. It's still salt and shark free.You do realize this is the same guy who recently posted venturing out into shark infested waters in a rickety homemade boat, bow and arrow in hand and bringing back Leopard sharks for the dining table, right?
You got the wrong guy. No sharks in Lake Eire. It's still salt and shark free.![]()
My First Fishing Boat
In the mid 1970s, I lived in a rental house overlooking the estuary area of Morro Bay, CA. I also fished a lot here and there on inshore waters. One Spring day, at low tide, I noticed that there were hundreds of sharks out in that estuary. So, the next weekend, I put together this 8' jon boat, made of a sheet of 1/4" plywood and a couple of 2x12s. I fiber glassed the joints and painted it green with a gallon of green paint I had around the garage. Then, I started hunting sharks with a bow and arrow as the tide was changing. Frankly, I was meat fishing, since my income was very, very spotty at the time.
A few years later, when I had started working as a freelance writer, one of the first articles I sold was the one below, published in Western Outdoors. Soon after that, I started seeing other boats out on the water, doing the same thing. I did a few more outdoor articles, but soon moved on to writing other types of things that paid a little better and had a larger market. An interesting period of my life, and the only boat I ever built. Not much of a boat, but it worked.
I missed that article.Don't think so....
Hes already admitted to not working on any vehicles and all his personal vehicles are under warranty so he doesn't have to do any work to them.Have you posted any pics of your small toolbox setup?
Same. Mine are all SAE except for 14mm and 18mm.I'm fairly certain most of mine are SAE, aside from a 14mm 12pt.
I was going to say something similar. There's no redundancy - use your 5/8" on SAE vehicles, your 16mm on the metric ones. We've got a civilization to run, don't be a ******.This is the only reason I have redundant spark plug sockets in my box.
I used to drive a Ford Bronco in the 80s/90s so I had the 5/8s.
But since 1998 I've only driven Toyotas. (two 1st gen Tacomas and a Prius). So now I only use 16mm and 14mm.
A wobble extension will take care of that. Sometimes, though, you need a real wobble joint on an extension. Or even two extensions with a wobble joint between them and another one at the socket end. A guy does what's needful.
That'll get in there, probably. Still, there are some spark plugs on some cars that are hella hard to remove and replace. I was shocked on my 1993 Ford Ranger which had two plugs per cylinder. One on each side of the head. 8 plugs on a 4-banger engine. And they fired at slightly different times, to boot. Emissions, I suppose. The ones on the left side of the head were almost impossible to get at, without removing the exhaust manifold, and everyone knows the perils of doing that on an older car.How about : "getter"
That'll get in there, probably. Except that assembly is pretty darned long and you can't take it apart. Still, there are some spark plugs on some cars that are hella hard to remove and replace. I was shocked on my 1993 Ford Ranger which had two plugs per cylinder. One on each side of the head. 8 plugs on a 4-banger engine. And they fired at slightly different times, to boot. Emissions, I suppose. The ones on the left side of the head were almost impossible to get at, without removing the exhaust manifold, and everyone knows the perils of doing that on an older car.
Anyhow, I never changed them. When I got the pickup it had 247,000 miles on it and was running OK, so I just ignored the plugs and drove on. I had it for three years and maybe put 6000 miles on it in that time. I sold it, still running fine, with the same plugs in there. Who knows when the last time the plugs on the left side of the head were changed. Maybe never.
Now, there are other engines with two plugs per cylinder, but they're on high-performance engines, not a 2.3 liter engine in a compact pickup truck.![]()
Extensions can come off the socket, which is problematic with ignition coils, since the socket comes off and is nearly impossible to remove from the well.A wobble extension will take care of that. Sometimes, though, you need a real wobble joint on an extension. Or even two extensions with a wobble joint between them and another one at the socket end. A guy does what's needful.
Right. I'm to old to have worked on coil-on-plug engines. But, generally, they're a little easier to get too than some cars' plugs are. I'm sure my cars have individual coils, but I'm not going to be working on them. Warranty.Extensions can come off the socket, which is problematic with ignition coils, since the socket comes off and is nearly impossible to remove from the well.
This eliminates that problem, and its magnetic (at least mine is) so it holds the socket. Plus, it's knurled, so I can use it to get the socket started by hand, and then use a ratchet. Well worth the money.
Having experienced that once, I now use a locking extension on the socket when they're buried deep. Not saying your solution isn't even more elegant, but I bet that socket wasn't cheap.Extensions can come off the socket, which is problematic with ignition coils, since the socket comes off and is nearly impossible to remove from the well.
I looked it up. It wasn’t that much more expensive than the Gearwrench that I have. Mine are much shorter, and are not magnetic.Having experienced that once, I now use a locking extension on the socket when they're buried deep. Not saying your solution isn't even more elegant, but I bet that socket wasn't cheap.
Not counting the ones you have to pull the upper intake manifold off to get at them............................Right. I'm to old to have worked on coil-on-plug engines. But, generally, they're a little easier to get too than some cars' plugs are. I'm sure my cars have individual coils, but I'm not going to be working on them. Warranty.
I think it was around $15. Mine was Neiko, I think, but pretty much identical. Locking extensions are probably more versatile, though.Having experienced that once, I now use a locking extension on the socket when they're buried deep. Not saying your solution isn't even more elegant, but I bet that socket wasn't cheap.
Dude, I love me some gaffers tape.Prior to the Koken extended spark plug sockets I now use I’d always use gaffers tape to secure the socket to the extension.
Be careful pulling the wires off the bottom ones, only available from Ford, you buy them individually and half the time the dealer around here only has 2 in stock......................................I can't find where to sign up for GJ therapy. My only vehicle now has a Ford V8 with 16 plugs. How many sockets do I need? Will I ever be OK?
