Seam between floor and wall- Epoxy prep
So I've grinded my floors and cleaned them. Looking to do the rest of the prep. I've attached a photo of where the floor meets the wall. There's this pretty nasty seam.
Considering I'm going to epoxy what should I do about a seam like this? Are there specific products I should use to seal it?
Also where the grinder didn't make great contact near the wall, is that a guaranteed failure point unless I angle grind completely to the wall?
Thanks
edit, not sure if the image is properly attaching, here's a link https://ibb.co/CHx6q9c
Shea
California
You need to grind the area near the wall as well. You can pick up a 4" angle grinder from Harbor Freight for $15 and a 4" turbo cup wheel from Amazon for about $11. Wear a respirator because the concrete dust will be heavy unless you have a vac attachment.
After you finish your floor coating, you can fill that seam (expansion joint) with a self-leveling polyurethane such as SikaFlex SL.
T
So you recommend not filling the joint and epoxying over the joint? Just epoxy up to it and fill it later?
Thanks
Shea
California
Thanks
Epoxy up to it and fill later. The problem is that the joint can expand and contract with large temperature changes. Epoxy does not flex. If you epoxy over the joint, then you run the risk of the epoxy cracking somewhere along the joint later.
FJ4FUN
NorCal
As has been already stated, grind all the way to the edge, coat to the edge, fill void with flexible joint filler after coating has cured, grab some pizza and enjoy! :beer:
