Delta Bandsaw Help
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
I am working on my Delta Bandsaw project, (when l post pictures, don't laugh at the different colors between the base and the saw, the base will get repainted later.)
anyways, I need help with the base right now, The places that sell the replacement want crazy money for the parts, so I need to fab. them.
If someone has this base, I need the dimensions of #257;cover,
#261;Stop ( looks like a metal strip,) and need to know or possibly if someone has it can take some nice big, clear photos, of how this thing is put together. There is part # 263;bumper, (there are 2 of them) and part # 262 2 latch, (there are 2 of them also).
Need to know how the bumpers and the latch's, and the stop work.
Also need to know the dimensions of the "Stop" too.
Mine is missing, and I have no Idea how it is put together.
I am sure I can come up with something on my own, but I would like it to look as close to factory as possible.
mrbreezeet1
OK thanks,
Here is the table stop I made, and the clamps I made that hold that metal box/belt guard to the base.
The table stop sets on a 5/16X18 bolt coming up through the casting with a jam nut on it to lock it. The Idea is If I want to tilt the table to the left, I tilt it 1st. to the right, and pull the table stop off the bolt, then tilt to the left.
The places that sell delta parts want $90.00 some dollars for it!!!
The clamp with the round head screws shown, is the OEM delta one, and the two I made (only one shown) sport the hex headed bolts.
The places that sell delta parts want around $15.00 each for the clamps!!!
And a picture of Cleopatra for the hell of it.
mrbreezeet1
You might want to check over at OWWM, if you have no luck. You can probably find a complete stand, reasonably priced.
http://www.owwm.org/
Thanks, Yeah, actually found a door there.
Worked on the blade guard tonight. Thought you might be interested in what I came up with for the brackets. I was going to try and find some at the OWWM classifieds, but I came up with this.
Clamps that hold conduit to a wall. Had to re-shape them a little. Worked out real nice though. The wood is white Oak.
Got a coat of Poly. drying on it right now.
mrbreezeet1
Have a nice cast and machined 7" pulley I found for a dollar at a flea market, 3/4" bore and all, but no keyway.
Might be a bit unorthodox, but I mounted a file in my tool post of my Logan, and using the carriage like a shaper, cut/filed the keyway.
Didn't turn out too bad.
GeoBruin
Is that frouned upon?
If it's bumped up because someone has helpful information to add, or because someone has a similar issue and has questions or clarifications, it's absolutely not frowned upon.
If it's awakened just to rag on the OP and adds nothing to the discussion, I can see how it could be viewed as just cluttering up the front page.
