Proto Tools Picture Thread - Post Yours!
JohnDeere
NE Ohio
An interesting fact: Most Stanley Proto adjustable wrenches open larger the other brands of the same size. For example the 4 inch one opens to 9/16 as opposed to 1/2. @d42jeep if you open the second one from the top all the way and compare it to a regular 10” it will be larger.
Mike'smeatshop
Now I know the middle pliers are Proto and the bottom pliers are McKaig Hatch but what are the top pliers with the 166 stamp? Thanks.
Spotted this 1/4” drive box a an estate sale this morning. It was filled with discardable tools other than two of the original tools. We also found an adjustable wrench and a 1/2” drive deep socket. I ended up adding my miscellaneous Proto 1/4” drive sockets to the box for storage.
Etchase
Hawaii
I finished cleaning up my abused 12” adjustable wrench. It looks a little better in the pictures than real life. IMG_9009.jpegIMG_9010.jpeg
Before adding it to the Proto drawer, I got the other ones out and shot the adjusters with some WD40. IMG_9011.jpegIMG_9012.jpeg
Since you had all those out, could you tell me if those have slotted screw adjustment shafts, or are some pressed in? If there are any pressed in, do they all have opposing holes that let you press them out? Just trying to figure out when the transitions occurred. Or I should just ask do you know when they went to a press fit and when they did away with the hole that allows pressing it out. Thanks.
If you send the catalog along to Mark Stansbury he can scan it and put it on Internet Archive. He is a GJ member so you can send him a PM to make arrangements.
JohnDeere
NE Ohio
I think that the pressed in screws were a Stanley Proto thing. The ones with the opposing hole to press it back out is Ingersoll Rand, and I am pretty sure all of the ones with screw are before proto was bought out at all. I do not know if early ingersoll rand adjustables have screws or not.
rogue321
The Proto screwdriver I pulled the handle from was super hard to get off. I almost gave up because I thought I was going to break the plastic. These things were well built for sure! Unless you can find a bigger handle, you wouldn't be able to make the hole any bigger than I did..
Most of mine do NOT have slotted screws and don’t come apart easily. It seems that there may be a correlation between slotted screws and unreinforced hanging holes. Here are the results of the survey. Only the 4” Proto LA and Mfd. without reinforced hanging holes have slotted screws.
I hope that tells you what you wanted to know.
JohnDeere
NE Ohio
Seems like my guess lines up well with Don’s findings, and it would appear that early Ingersoll-Rand Proto adjustables have screws. I would also guess that earlier Stanley Proto wrenches had the opposing hole to drive the pin out.
Etchase
Hawaii
Thank you so much for going thru all the effort to not only check, but photograph all the sides. Press fit is much earlier than I thought. There are a lot of adjustable wrench photo’s out there but almost all are side views.
You’re welcome. I tried to capture all of the date codes. Happy to contribute to the collective knowledge. I was surprised by how few slotted screws there were. I imagine that reducing manufacturing costs was a large factor in the change. 🤑
Etchase
Hawaii
The other thing in that time period was click stop which might benefit from a pressed shaft. I’ve never taken one apart. Cost saving would seem minimal to me, but they made a lot of them and every nickel counts.
Nice assortment you have there and those pictures are great!
These three are Clic-stop. The feature only really works well on the dark finish one. The other two chrome wrenches function pretty much like any other adjustable. IMG_3821.jpeg
Etchase
Hawaii
I don’t know enough about how to date those to know if they are early sixties, or early 70’s., if they are early sixties it would narrow down the date of when the slotted screw disappeared considerably. The one with the date year code 1 and the full patent number looks like a candidate.
