Best flooring for garage?
zimm17
Virginia
Just bought a house that has a 2 car garage with an ugly concrete floor. What are the current best solutions for a covering? Race deck? Some kind of epoxy coating? I'm tough on floors- floor jacks, dropped tools, some hobby welding, grinding, etc.
My brother's place has ventilated race deck, and after working in his garage for a few days, I hate it. Too uncomfortable to kneel on, swallows small hardware, and I wouldn't know where to begin with a sloppy oil change clean up.
ATC
VA
So it's just ugly? Not cracked, uneven, etc...?
If I were using a garage like you are, I wouldn't worry about the floor. Use it as-is.
I guess if I had to do something, it would be an epoxy coating.
Z
zimm17
Virginia
No it’s fine. House is only 5 years old. Maybe you’re right. I can take that money and buy a new air compressor….
4 Ever-Fish N
Deep East Texas
I'd definitely go epoxy. I put epoxy down when my concrete floor was new. There are some stains, concrete cracks, etc but overall it still looks good. It may take a lot of work to get your floor clean enough to have the epoxy stick.
kbuhagiar
Escondido, CA
I installed MotoFloor (which is Costco's licensed version of Racedeck) on my well-worn 2-car garage floor several years ago. I loved it, easy to trim & install, easy to clean, and it really brightened up the place. Only complaint would be the slight clackity-clack sound from walking on it. Sold the house in 2021 and left it there, new owner loved it too!
kbuhagiar
Escondido, CA
The original RaceDeck (or Costco's MotoFloor) is a much better choice, IMHO.
kbuhagiar
Escondido, CA
I've got a 1950's detached single garage that I am looking to improve into a more usable workshop space. Repairs to the roof and window have resulted in a drier environment, my attention is now turned to the floor. It is made up of a mixture of concrete and concrete slabs with no DPM below. This seems to suffer from a little condensation in winter and a gap between two of the slabs allows damp upwards in very poor weather. The biggest problem is the concreted areas are quite dusty. My play is to lay a DPM over the existing floor and then install interlocking PVC floor tiles over the top. Does anyone see an issue with this plan? The floor is mostly level, although my biggest concern is preventing the existing floor from breathing and causing more problems. There is a DPC in the single skin brickwork one course up, I guess the DPM would need to lap up this course of bricks? In an ideal world I would rip the lot up and re-lay the slab however this would have to be a last resort being both time and cost prohibitive
yomav,
You may want to start your own thread and post your query there.
It's considered bad form to hijack someone else's thread.
frankd
Long Island, NY
I have a product called "garagedeck" made by bigfloors.com. I do like the product but the main reason I installed it is because the original concrete floor is from 1955 and its cracked, pitted, patched, etc. If I had a good solid/sound floor, I'd probably just put some sort of sealer on it or something to prevent the concrete from staining or soaking up oil spills.
dcg9381
Austin, TX
I've done epoxy before. I now use polyurea and will never look back. It's less expensive, you can install it as a solid color and flake it (identical to epoxy) - less prep, easier to install (less skill). Did I mention cheaper?
