Band saw vs metal miter
sjvicker
SW Washington
I currently have a band saw comparable to this grizzly: https://www.grizzly.com/products/grizzly-7-x-12-1-hp-metal-cutting-bandsaw/g0561 and no matter how much I fiddle with it I can't get a square cut and its even worse if I try to do a 45deg cut. It also takes up a lot of space for how often I use it.
I've been seeing adds for the evolution metal miter saw and am thinking about changing things up. Most of my cutting is 2"x2" or less and less than 1/4" wall so this seems like a perfect fit for what I typically cut. https://store.evolutionpowertools.c...55mcs-mitre-chop-saw-heavy-duty-metal-cutting
Has anyone used the new evolution saw? Any downsides? I know its expensive but I'd sell my bandsaw to cover as much of the cost as possible.
isb cornbinder
Have you tried installing a new blade on your saw?
NEVER EVER use a carbon blade. ALWAYS use a bi-metal blade. The carbon steel blade will likely lose most of the teeth on one or both sides when it ties to cut the resistance weld in tubing. The bi-metal is 3-4 times a much money and it will give 50 - 100 times the service. Make sure you blade tension is correct. a loose blade will wonder. Google for correct tension. reset the blade guides.
sjvicker
SW Washington
yup, no difference with new blades. I dont think there's a problem with the saw, I'm just missing something in setting up the blade guides. At the end of the day, even if its set up correctly its a space hog and tough to do 45deg cuts with long material in my shed.
readhead
Durango, Co.
To answer your question, the Evolution saw works well but is limited to smaller sizes. Blades will be expensive. I have one but I use the band saw a lot more.
darkzero
SoCal
I have the same 7x12 bandsaw except mine is branded MSC, made by Rong Fu. Mine cut straight out the box, even came with a test cut sample. They're not hard to adjust, just need to get familiar with it. I had a RF 4x6 previously so I learned on that. I only use Lenox bi-metal blades.
Depends on what you work with but I would never give up my bandsaw for a glorified chop saw. Chop saws are way too loud for my home garage & I don't like that they throw sparks/chips. They do cut quicker but for my needs I rather have a bandsaw.
Man $850 is a lot for that Evolution saw, that's what I paid for my 7x12 brand new from MSC.
GeoBruin
I had an evo saw (the one with a vise, not the "miter saw" version) . I've also owned a Grizzly Bandsaw, somewhat smaller than yours but still floor mounted on a base.
The key benefit of my grizzly saw over yours is that the head mitered. That cannot be oversold. It's a huge time/space saver. I loved the Grizzly saw but it just took up too much space in my shop. So, I sold it and wound up with a benchtop mitering bandsaw made by Femi. It's almost as small and every bit as light as the Evo saw, but has way more capacity and a mitering head. It also cuts super straight which admittedly took some fiddling with the Grizzly.
I don't think I would own another TCT saw after owning a couple bandsaws.
Anyway, just consider one of these as part of your search. I actually ended up with this one but I got it used.
BTL-A4
Santa Clarita
I say buy the miter saw. That bandsaw you linked to is huuuuge. Get yourself a smaller bandsaw to cut metal; I find mine indispensable.
isb cornbinder
When starting a new blade, run the blade at a reduced tension for a few minutes then tighten to specification. You should do the same start-up procedure if the saw has been sitting for a long time. (More than a week) I have not started my bandsaw in over 2 years.
Rusted Nut
Northern Arizona
If you’re having trouble getting good cut, check to make sure the workpiece is level. My garage floor slopes, so I need to adjust my roller stand to make sure the work piece is level. Also use a guage to adjust the saw stop to the correct angle to the blade. I have a similar jet bandsaw, which cuts nicely.
slowtwitch73
Hellgate
When I got a tensionometer, I was floored by how much tighter the blades were supposed to be that what I had been doing by feel for years.
Fwiw... unless your using a tensionometer, the blade is more than likely too loose.
LeeG
Phoenix, AZ
Here’s my long term review of my bandsaw. Not cheap, but accurate and small footprint.
Lee
Retroman
Mojave Desert
I have a MK Morse Metal Devil its great for what I need. Ya its loud and throws metal shavings but I get good accurate cuts every time. I bought a cheap magnet broom from HF to deal with the metal chips.
