3.25 inch open end wrench
L
lynnbilodeau
Oklahoma
Even if you could get one, how are you going to.have enough strength/power to tighten or losen it?
Not that much torque required. I can use a large pipe wrench, but it is a restoration project, and I don't want to mar the nut if I don't have to. We are restoring this magnificent late Victorian masterpiece built in 1902. It is the State Capital Publishing Museum in Guthrie, OK. Shameless plug: https://publishingmuseum.org/
I need to move most of the first floor radiators so we can get to the windows. I do not believe the radiators have ever been restored. I would rather use a wrench with smooth jaws instead of a large pipe wrench. I am probably the only one that will ever notice marks on that nut; still, I would rather do it without making marks.
We plan to move them in two weeks on the 17th of June, so I have some time to line up everything I need.
bigfunwmu
S. MN
You sure that opens to 3.25? I could not find that spec for jaw opening.
Thanks for the link.
By tape, mine opens to just a bit over 4.5 inches at full spread. The jaw depth is only about 2-1/8 though. It will grip 3.25 hex or octagon just fine.
darkzero
SoCal
bwringer
Indianapolis
I'd make a wrench rather than drop over a grand... the hard part would be getting the jaws smooth enough to avoid marring the nut.
All that said, I'm not sure about the idea of smoothing a pipe wrench's jaws by grinding or with inserts; they're designed to dig in. It may or may not work depending on the torque needed. You might need to pay attention to the angles of the inserts, since pipe wrench jaws are not parallel.
While helping out around his farm, I once asked my Uncle, "Hey, what's that big green wrench for?"
He immediately shot back "Big green nuts" and walked away.
Thus I was enlightened.
hefnerconstructionlc
Kansas
Before you go to break it free warm that thing up with the portable propane torch. It'll help that not come off even easier. To help minimize your scratching situation.
RPH
Michigan Thumb
Wrap a leather belt around it after warming it up. The belt will protect against gouging if you’re careful. One reason to keep old belts of different kinds handy for cushioning.
KenC
oklahoma
make a crews foot.. plate as thick as the nuts flats,, doesn't have to be machined and pretty, welded pieces will be fine
weld on a pawn shop socket of your drive choice for connecting the breaker bar
L
lynnbilodeau
Oklahoma
Thanks for all the leads. I have a large crows foot wrench that I got at a local flea market for $3. Just went an checked; it is only 2.75.
I have some left over leather strapping from replacing the belts on a manual press circa 1860. I already have a pipe wrench I think will go that big, so will try it with the leather wrapped around the nut. We aren't moving them for another two weeks, so I have time to figure out something.
IF I can remember, I will update this thread with results. This is one reason I really like this site; there are so many knowledgeable folks from almost every discipline under the sun.
Thanks again.
L
lynnbilodeau
Oklahoma
The big wrench from McMaster Carr is only $1,018.83 Each.
Was getting ready to pull the trigger (tongue firmly in cheek) when I realized it was black oxide. Nope; over a grand it better be polished chrome.
RPH
Michigan Thumb
Hit the flats on the Union hammer. If you have 2 weeks before opening them. Then let the time work in your favor. Penetrating oil and light taps around the union will help loosen it. The belt trick works!
whateg01
doo dah, kansas, usa
Even if it opens that far, I can't see how it has enough reach to cover the flat on a fastener that big. I would also burn one on the plasma table. I would follow that up with smoothing the jaws on the mill to reduce and marring. I might also make it a crows foot so it's smaller when stored and I could use a ratchet to get on it at different angles as needed.
joel_400
Nw ohio
I've got one of these. I work on man lifts for a living...nobody in the shop had a 3 inch wrench for a hydraulic hose one day...I bought this the next time I saw the Snap on man. Super nice quality wrench! Very heavy as well...just the weight alone will give you some extra oomph!
Joel
