spare tire winch socket
pizzabooty
Highland, MD
weird question, and i wasnt sure how to word the thread title, so bare with me.
i'm a professional mechanic and a lot of times come into contact with spare tires that have to be lowered to the ground from under the car (although usually, i'm lifting them back up lol). it is definitely a hassle needing to use the kit that comes with the car to lower the winch and then lift it back up, so i was considering buying a female pipe plug socket to do the job with an impact.
in the past, i've used 12pt sockets, typically either 13-14mm, but that's sketchy at best so i was just wondering: has anybody else had this crazy idea? if so, have you found a specific size of socket to be more or less used?
4xdog
Santa Fe, NM
For some inexplicable reason, my Lexus RX spare tire winch -- inside the car -- has a pentagonal head and a special socket. I'm guessing -- hoping even -- that crazy system isn't common?
P
pizzabooty
Highland, MD
i've seen this before! i think i've seen it on a couple toyotas, so that tracks. it's very uncommon though.
retDAC
near Huntsville, Ala.
Toyota started that on some cars with winches. Even had a recall to replace the hardware to 5 point. Tire techs were using impacts and damaging the 6 point hardware.
Friend had an '06? Sienna he bought used. After a few years he needed to change a flat and discovered he lacked the special socket! :eek:
All I can say is the Transit Van I drive has a female square, so male socket would do the trick. It's been a while since I dropped the wheel and can't remember if a 1/2" extension would fit or if it's larger.
That said, the tool kit *****. The bottle jack barely works. The 4 or 5 snap together extension jack handle is nonsense. I have to go secure the jack today as my coworker just had a flat and apparently left it flopping around under the seat.
Badger 13
Northern Idaho
I have a Steelman" spare tire removal tool for my truck. They make them in different sizes. This might be food for thought.
PelicanPines
Again... on the holder for that set... "DO NOT USE WITH IMPACT"
Nice set by the way
mervyn
Missouri
That's a Lexus / Toyota thing. They don't all have it though. I hated those things.
4xdog
Santa Fe, NM
...Tire techs were using impacts and damaging the 6 point hardware...
Don't use an impact... Use a drill. The impact will damage the mechanism.
That's the best explanation I've heard yet for why the winch has a pentagon-head nut! Also why the special socket has a large ring at the top -- not only to fit the crank, but to make it harder to somehow chuck it.
Thanks, guys.
