Cement question
wantacoe
Sycamore, il
For some strange reason whoever built my building (50 years ago) put cement to the inside of the post in my doorway, So the threshold was not on the cement. I need to cement about 6"x6"x36". 2 questions, What is the best to put under it (gravel, sand etc?) Since this will be a separate piece how can I anchor it to the floor to keep it from shifting? Thanks
whateg01
doo dah, kansas, usa
They did that so water doesn't run in under the door. You should do the same, keeping your threshold a 1/2" or so below the floor.
Somebody else can suggest how to go about it.
KenC
To keep it from moving, drill into the edge of the existing floor for some 3/8" rebar pins, 4" deep is enough. Use some Sika (or equivalent ) anchor adhesive to tie them in. Tie a couple pieces of the same rebar to those pins, running lengthwise of the new pour. Form and pour. I'd drop the new piece a little below the floor and/or slope to the outside.
Zeke
I think I'd work a railroad tie a bit to look nice and bury it right where you need. Later, if you decide to put in a threshold and door seal, just screw it down. I'd probably set the tie down in a bed of mortar a couple inches thick. You can seal the tie to the 'concrete' inside the poles.
Kurt4440
Western New York
Pictures always help us help you better.
Answers:
1. Gravel will work.
2. Install Tapcon screws into the concrete and leave them sticking out about 2". Clean up the concrete dust and the concrete you are bonding to. Apply a concrete bonding agent to the concrete. Attach a piece of wire mesh to the Tapcon screws with wire ties.
Use about a 4" slump concrete and be sure to consolidate it.
Monza Harry
Windsor ON
Re bar is now at my HD in green epoxy, an excellent idea/upgrade. To anchor the rebar there are many options, I've used PL Premium and mortar also the anchor holes should be splayed for additional holding power clean the holes thouroghly . Lots of excellent suggestions above cherry picking parts of each is also a possibility. Harry
