Topside Creepers (again)
OX1
Jackson, NJ
This seems to be the most recent thread on this.
Seems you can get this one that claims 75" off the ground I assume.
My big offroad rig needs 68" to the top of air cleaner. Wondering if above
will really clear. I'm only 150 lbs, so won't be much flex I suppose.
Other idea is I have a regular creeper I never use, and two engine stands I bought 11 years
ago to make a rotisserie (which I never did). Get some kind of short ladder and make my own.
Badger 13
Northern Idaho
I was looking at these a couple of years ago, and Traxion seemed to be the go to one. I see now that Jegs also has one that doesn't look too bad.
Callelle
Depew NY
I was just looking at one of those on Amazon having recently starting working on big rigs. Vevor sells one that looks identical for $150. I might take a chance and try out the Vevor one.
ronkz650
Denver, CO
I got a Traxion from Summit a few years back. It works real good, but it looks like the new one is a different design. It looks good and should work fine I would imagine.
WWheeler
Middleofnowhere USA
I have a traxion 3-100. Bought 8 years ago from Tooltopia when it was $178.86 shipped. Damn prices have really went up since then.
I absolutely luv it when I need it and I hate how much space it takes up even with the legs folded up in my garage.
SteadyC
CA
PSA. I had sent back two of the 3-700's and just ended up keeping the third(which was broken). The weld on the main support is really bad and came/received broken twice. All three units I received were poorly welded.
I just used a scrap piece of angle and drilled/bolted. Works fine now, but pretty crappy having to fix a new item.IMG_0193.jpgIMG_0192.jpgIMG_0191.jpg
