How do you keep your garage cool during the summer?
timtim2008
Peachtree City, GA
with out installing an AC unit?
do they make garage door fans? (not just the ones you hang from the ceiling) i mean one that can install/mount on your door, and goes up and down with the door, too would be nice..
i would love this
wsettle
I use a big 4' roll around shop fan which keeps the air moving but it will do little today as it will just push 104 degree air around.
bochnak
Mt. Prospect, IL
I have the blower motor from my old furnace out in the garage. I set it up outside to **** in cool air when I'm out there at night. It also keeps bugs under control since they can't fly in 25mph winds.
Looks like this:
MScott
Eastern Ontario
Depends a lot on where you live. You cannot make a garage cooler than the outside air....all you can do is reduce the effect of the heat.
First, insulate, insulate, insulate to reduce the amount of heat transfer from the sun-baked exterior. Make sure the garage doors are insulated.
Second, make sure the atic area is well ventilated. Use powered or whirlibird vents to keep the attic as cool as possible. A light coloured (colored for you guys) roof will stay cooler than a dark roof.
As stated, use multiple fans to keep the air moving. You will feel cooler with a breeze on your body and persperation will evaporate more easily.
If possible, keep the garage doors closed and use a dehumidifier to reduce humidity. Drier air always feels cooler.
NUTTSGT
Northern Central Ohio
My garage has been too damn hot this year. I'm not going out there when it's 85+ and humid. After I put a new floor in, I'm dropping the ceiling to try help cool it, heating it is no problem.
dankicksass
New Jersey
Attic fan, exhaust fans in the rear of the garage, oscillating intake fans in the doors. it's not pretty but it makes things livable.
Heavy Metal Doctor
Mason Dixon Line
High humidity makes even the 85-90*F range feel rotten. I can't do much but use a few fans to try to keep air moving through the shop...beyond that, it's just keep a jug of cold iced tea or water handy and sweat....I find that once I'm completely sweat-soaked I stop thinking about it....
79firebird
Victoria bc
i did the same as bochnak fan from a old furnace they work real good and are portable. works good when welding a lot also moves all the fumes away
haugy
Nashville, TN
I hope I'll be keeping the pole barn cool with insulation, to fans mounted high in the upper corners to circulate air, and an window A/C unit.
PurdueSD
Indiana
I built my garage 4 blocks deep in the ground. Its well insulated and will easily stay 10-15 degrees cooler than the outside air if i keep the doors shut.:pimpflash
Jack Olsen
Los Angeles
That's my attic fan in the original picture. It was only $80 and it recirculates all the air in my garage every five minutes (by its specs). Since I've got a flat roof, it was pretty easy to install. It can also be used with a traditional roof, though.
For really hot days, I'm currently adding a small AC unit I picked up second-hand. It's a portable one that vents to the outside through holes I'm cutting in the wall. We'll see how well it works.
Steve in Mi
Mid Michigan
Wrong as PurdueSD already pointed out and I second. I often see greater than 20 degrees difference. Insulation down to the frostline means that the 53 degree ground water temp is pulling heat out of my shop leaving it cooler and comfortable. No A/C and my shop doesn't go above 73 downstairs in the Summer. It gets a little warmer upstairs, maybe 2 - 3 degrees. In the Winter it doesn't go below 63 degrees downstairs and again 2 to 3 degrees warmer upstairs. Insulate well and keep it closed up as much as possible has worked for me.
1Garageman
Columbus, Ohio
I know what you mean fellow Ohio'an. It is freak-en how and humid in my garage also. I feel like keeping the garage doors down and buying a cheap air conditioner for it.
red baron
I open the bay door. :lol_hitti
But it doesnt get too miserable this close to the coast. :bounce:
61scout80
Crestwood, KY
I use an evaporative (swamp) cooler. Not so good now that the humidity is up here...
Looks like this:
yeah, but how to you keep your hammers from blowing away???? :bounce:
geaugafletcher
Ha! Keep it cool in 100 degree weather? You better figure on honest-to-Pete air conditioning or just get up before the sun does. Open door? Attic fan? Portable A/C? Passive cooling through the slab? Fat chance, the weather around here will scoff at your feeble gestures.
51rider
London, England.
Jack,
you should have no issues with that portable unit-we used one to provide 'temporary' a/c to a server room for about two years!:wtf:
To the OP-easy move to England where we never have a summer anymore:(
W_A_Watson_II
South East MO
Turn of the incandescent light!
Actually lots of insulation, keep the doors closed and run a dehumidifier. Should have also installed a small window unit, but haven't, yet. Shop creeps up to the mid 80's when it's in the high 90's outside, but humidity stays at 50% (or less).
lawfarm
NorCal
Keeping air moving results in huge 'perceived' reductions in heat. I keep a regular household box fan in the garage, with a 'custom' piece of 2x4 next to it. When I'm working in the garage, I tip it back and rest it on the 2x4, and point it at myself. That's good enough to keep me reasonably comfortable even in the worst that Illinois has to offer.
yzair
Evaporative coolers also known as swamp coolers work pretty well until the humidity climbs
TagMan
Alvaton, Kentucky, USA
I've got a lot of wall & ceilling insulation for starters. The concrete floor gets really cold in the winter and in summer, I keep the overhead doors closed as much as possible so that the floor keeps the whole place nice and cool. I'm also pretty well shaded from the sun by trees for most of the day. After a LOT of heat & humidity this summer, my shop (30'x40'x12' to the rafters) was 73°F today. I also have a dehumidifier running in the summer.
stikman56
The house we built,the furnace is in the garage, we had a heat pump installed too. I had the garage insulated and sheetrocked, it stays about 20 degrees cooler in there in the summer. It's great year round in there because of that. Issue is I do all the work in the shop, it has nothing for heat or cooling, but the garage is always comfortable.
apollo11
State Of Reality
any pics? :bowdown:
Found an inexpensive solution for turning a hot garage into a shop. If your garage is like mine; hipped roofs, full sun, and no insulation, your problem is radiant heat coming through from above. Traditional insulation is too expensive and may cause moisture build-up issues. The solution is to reflect the heat back upward before it gets into your shop space, and vent it up and out. If you do this, even a relatively small portable air conditioner can keep your shop space reasonably cool. Here's the set-up. I bought wide and narrow rolls of cheap reflective roll insulation ( not perforated) at Lowes. First, I ran a narrow (18 inch?) strip of reflectix from the top of the wall to the ridge board STRADDLING (not touching)the diagonal hip rafters, and stapled it to the common rafters alongside. If you span the hip rafter, you create 4 air spaces that the common rafter spaces can spill hot air into. I then covered the common rafters with wide reflectix. In all cases, I left a small (1 inch or so) space at both the top and the bottom of the runs. The final step was to vent the gathered hot air out the peak of the roof. In my case, I rebuilt an existing cupola that sat on the ridge board to cover holes cut alongside the ridge boards. You could also use a modern ridge vent. My garage is in full sun and even on a 95 degree day, I have not needed a vent fan. Cheap, quick, and works great.
kbs2244
Shade
I have trees
But if you are in a treeless area think of a false roof made of lattice or snow fence above the real roof.
It will keep off the sun and provide air circulation for the escape of what does come through.
CoogarXR
My insulated 24x24 cools easy with a 12k btu window unit. I know you said no AC units, but why not? LoL. This is a great time to find one cheap. People are taking them out for the season...
Lelandwelds
Central Texas
1. Work at night
2. Make sure roof is white.
3. Shade
4. Radiant barrier with small air gap.
5. Tall ceilings for hot air stratification
6. Open doors for cross breezes
7. Drink iced tea and sweat a lot
8. Install micro misters high over roof or door opening
9. Limit concrete and asphalt
10. Build a tiltwall garage and insulate exterior
11. I know one man who bored into cavern located under his house and shop. Added a fan and some screen for the bats. Works great.
12. 4 ft shop fans on wheels.
13. Funnel prevailing breeze into shop
14. Operable windows as high as possible. Open door near work or to catch breeze.
15. Build your shop in old mine. Works great.
16. Move to Norway
17. Install cupola
18. Install large solar chimney on roof peak
19. Take a break
20. Use the emergency shower
21. ALS ice bucket challenge
My old garage was hot. It had to be some kind of special project to get me out there in the summer.
Lelandwelds
Central Texas
Has anyone ever covered a black roof with polygal and made a solar chimney with this style of metal building?
peter2772000
Montreal Can. & Cape Coral FL
None of the suggestions (except adding A/C) will do anyone any good if you park a car in the garage right after a drive home....in the summer. And no, waiting 'till the engine's cooled off with the hood open is not practical
