my $25 Wilton 1750(pic heavy)
t100
my ultimate question: is it a Chinese or Original? mfg date?
I took my chances picked it up at a garage next to a gas station. I didn't know what it was at that time because it was covered by a horrendous amount of grease and metal shavings. no brand casted into the body, also the jaws were broken and pipe inserts were missing. the only hint I got was the brass end cap at the back of the vise looked like a Wilton. it turned smoothly and didn't make any noise.
I got it back to the shop, scrapped off about 1/2 a coffee cup of grease, took it apart, then dumped everything in the solvent tank for 4 hours. at the same time, I dug out a piece of scrap 1/2" 6061-T6 aluminum plate, made a pair of jaws on a band saw and mill.
here are the pictures after I put it back together:
Slip_Kid
Rhode Island
It sure looks like a Wilton, maybe a knockoff. But for $25.00 it's still a good deal, nice job on the jaw pads.
GeorgiaHybrid
Extreme NW Georgia
I think it is a fairly new (uses the side plate stickers) Snap-on vise made by Wilton. The base itself and what is left of the original paint are a dead on match to one on a local dealers truck.
Yours has a 5" jaw but is very similar to this one:
Snap-on vise by Wilton
tonydanzah
the champagne of people
it doesn't have to a snap on made by wilton, it could just be a wilton with the foil stickers like mine.
spongerich
Monroe, NY
It looks too well made to be a Chinese knock-off.
Check the bottom of the slide for a date stamp. Most Wilton bullets seem to have them.
Oh, and you ****.
autopts71045
Illinois
Nice vise, however if its not stamped anywhere "Made in the USA" I hate to be the one that tells ya..The upside is that new Wilton jaws are under $40.
GeorgiaHybrid
Extreme NW Georgia
Tony,
I thought about that (I have one just like yours...) but I have not seen a late model Wilton that had red paint. All of the late model 1700 series like ours that I have seen come with that green/blue hammer tone paint. Either way, it should have the date on the keyway on the moveable jaw.
And that was a NICE price on the vise.
T
t100
it could more likely be a Snap On, the shop I got from was full of Snap On tools, they are getting new benches outfitted. the guy said his dad put the vise on there probably 20 years ago and never moved it again.
all the markings are in the pictures above, I don't see any date marks on the keyway. the keyway and screw are probably newer than the rest of the vise 'cause they are in much better shape.
I searched other threads regarding Wilton 1750, from the pictures I've seen other posted, my is pretty close, only the number "1750" is on the other side of the moving jaw.
I'll double check on the keyway when I re-grease it, I'm waiting for the heavy moly based grease.
T
t100
update:
she's nakid now.....
is this the date code you guys talking about
now I need to ask a favor, if you have a copy of the mid-late 80's Snap On catalog, would you check if there's a p/n# WV1750? I called a SO guy, he told me there was a red vise sold by Snap On should fit the description, but that was before he took over the business from his father.
spongerich
Monroe, NY
4 86 is definitely the date code... April '86.
It's a little odd that it's not stamped USA, but I suppose it's possible that the COO was on the stick-on tag.
Have you tried emailing customer service @ Wilton? They might be able to help positively identify it for you.
T
t100
thanks, fellas. I think I'll paint it the original red. problem is the 80% humidity isn't the perfect condition for painting. I've got some self-ecthing primer on, will see how it goes.
autopts71045
Illinois
Nice 1750. Its original color was like Tony's listing up above. if it was an original Snap on I would paint it red. That vise would look very nice and original with Verde Green, a close match to the original 1750. Nice find and clean up!
autopts71045
Illinois
New Craftsman for $130.00. Made in China by WMH (Wilton) rated at 60,000 psi. That 1750 may have been made in that same plant. The world's going crazy!!
T
t100
that's why when looking for a vise, I wouldn't touch anything less than 20 years old.
Steve V.
Texas
The beauty of this is that he may be able to get the jaw inserts and pipe jaws from Sears for cheaper if they truly are the same vise.
Steve
Flash21
it seems, for some reason, the 1750 / 1760 / etc series didn't have "MADE IN USA" cast into the side of the vise. I think when the changed over to the 1755 / 1765 model series, they added that.
I'm not sure when or why Wilton made the change to add 1/2" to all their jaw widths (and the overall proportions are a little different)
autopts71045
Illinois
Yes, they are both mine, the newer looking one that says USA on the side is a 1997 and the other is from the early 80's. Wilton I believe first started making that body abroad, then they decided to make it here, and then they discontinued that # all together. Right now, I'm doing a make over on the older one. I have an extra sticker to glue on the other side. They usually clean up nicely.
T
t100
I grabbed the wrong RED spray can, duh. the color turned out to be pearl maroon. fugly as hell.
rough it up with scatchbright then 3 coats of blue Dupli-Color engine enamel. the actual color is darker than in the picture thou.
autopts71045
Illinois
Whoa! That is odd, first 1760 I've seen with that. Are those both yours?
Do you notice any other differences?
The 1760 without the engraved stamp on the side was made in 1985 the one stamped Made in USA is a 1997. One difference is the older one has the external end cap that holds the threaded assy, like the older typical Wiltons. On the 1997 model, newer generation, they made that holding assy. inside the rear of the vise. I'm going to see if the front jaw assemblies are interchangable.
autopts71045
Illinois
Nice thread t100 and a very nice restoration of what could have been in garbage site dump by now. You saved another one. From this photo, I guess Wilton didn't go by the Henry Ford rules of assembly line technique. The newer front jaw into the 1985 body and you can see that jaws are off by at least 1/4" Operation is at least smooth.
T
t100
by just looking at it, I think the major difference between the USA made and the current imported vises is the size of the swivel base. the import ones are totally miniature.
autopts71045
Illinois
I've seen alot of Wilton Tradesman and this is this first one I've seen like this also. The bases are the same on both, They might appear different in the photo.
autopts71045
Illinois
My 1750 taken apart for a thorough cleaning.
Nice comparison photo, a later production Wilton that was made here in the middle/later 90's that Wilton discontinued. That newer generation Wilton is today's style. They eliminated that back cap housing and moved it inside the tube. One excellent find!
T
t100
new pipe jaws
new stainless steel head bolts, modified the head to clear the screw
1FordTech1
Lawton Oklahoma
Great thread! Sorry to bump an older thread but I just got this vise in a garage sale along with a couple trucking sized ratchet straps for 30 dollars. I did a lot of searching on Ebay and decided it looked a lot like the Wilton ones there but found no Wilton name on it. Then I found this thread and looked at all the markings and it is identical to the one the OP posted. It has been repainted black but the bottom side still has the original red paint, so I am going to assume this was made for SnapOn and the foil labels are long gone. It has a production date of Feb 1985.
Thanks for this post which surely clears up some of my questions on the identification and certainly gives me pride in a great deal made! I will restore it and use it in my garage at home.
1FordTech1
Lawton Oklahoma
Mine didnt turn out as pretty as yours but here it is. I opted for a can of Chevy Orange engine enamel, high temp that I had laying around and a little sanding down of components. The original jaws were good enough to use for around home use. Ive asked my Snap On dealer to see if he can get me a couple replacement labels for it. You can see where someone had been grinding on something that was held down with the vise so its pretty scarred up from that, but overall a great find for home.
red93yj
hi guys, this is my first post, pretty excited about my new wilton 1760, I guess this was made 11-93, is that any good? I think its in good shape.
