Why don't higher torque (100lbf+) 3/8" torque wrenches exist?
Hannahranga
Happy to be proven wrong (preferable digital or click style) but given how good 3/8 stuff is getting why do 3/8 torque wrenches seem to stop at 100lbf?
dchawk81
Do you have a specific use case where a 3/8 is preferable?
H
Hannahranga
Mostly just trying to keep as much of my stuff 3/8 as I can, understand at some point moving to 1/2 or 3/4 is necessary. But thought 3/8 square drives were rated for 150Ftlbs atleast, tho abusing 3/8 stuff you can definitely do more atleast once.
dchawk81
Makes sense. I don't have an answer to your original question, I was just wondering.
You can use an anvil reducer to get down to 3/8 and it won't affect anything, especially if it's one of those troyka nesting doll types.
cvairwerks
Within hearing distance of Texas Motor Speedway
You ever try doing over 100 lb/ft on a 12" long wrench? I see guys struggle doing 165 lb/ft with a 24" one, and they are standing up and pushing down to get that torque.
Firebrick43
West central Indiana
It depends on the sockets. Some will, some thin walls will break. When you dealing with torque devices they tend to be very conservative because its not a precision tool.
Also your still going to need another torque wrench no matter what. A torque wrench that goes to 150 ftlbs has a minimum of 30 ftlbs.
That is to high for a lot of engine torques. Most 3/8 torque wrenches are 15ftlbs to 75ftlbs and 20ftlbs to 100ftlbs. You shouldn't operate mechanical torque wrenches at the end of their ranges.
Some electronic torque wrenches such as snap on are 5-125ftlbs but they are 700 dollars. Electronic ones have been pretty flakey long term from what I have witnessed. I would never buy one for personal use.
KnurledNut
n/a
I’ve found its less strain on the body to pull instead of push, where possible.
cvairwerks
In this case, it would require you to sit on the ground and have a large tire turning about a inch from the family tools....plus trying to wrap your leg around the jack. Wheel nut is about 24" off the ground when we change tires, and you are trying to keep a 4 1/2" socket on that nut at the same time.
AEAdam
SE PA
Unlike some submarine makers, good engineers try to work to reasonable safety margins. same reason sockets over 19mm aren’t usually included in 3/8” drive sets. The margin of safety is usually at least 2X. So if a bolt with a given head size needs a torque of X, good manufacturers want the drive to be good for double that.
3/8” drive is good to about 200-250ftlbs.
Reason 2 is, by adding capability at the top end of the torque wrench, you would lose accuracy at the bottom end. Most 3/8” clickers are 5-100. 1/2” are 25–250. And typically the lower 10-25% of the range can be inaccurate.
M635_Guy
NC
The point isn't the level of cranking a torque wrench can achieve, it's arriving reliably at the torque required. The longer the handle, the less chance you have at arriving correctly at the lower end of the torque range (too much work being done with a small movement at the handle). The shorter the handle, the lower the top-end of torque can be gracefully/reliably achieved.
dchawk81
I'd get a 1/4" drive for that tiny numbers stuff.
Which reminds me, I need to get one. Ever since I lost faith in my HF 1/2 I pretty much effectively have no 1/4 anymore.
