atikovi
My 15 year old $8 SAS muffs broke. 99% of their use is standing next to my compressor using a blasting cabinet maybe 10-15 minutes a month on average. Anyone like these 3M muffs on Amazon for $21?
I just bought a pair. Very comfortable and good noise reduction. Hopefully I don't drop these and run over them!My 15 year old $8 SAS muffs broke. 99% of their use is standing next to my compressor using a blasting cabinet maybe 10-15 minutes a month on average. Anyone like these 3M muffs on Amazon for $21?
That's only partially true. Good plugs do a decent job of straight decibel reduction, but hearing protection isn't that simple. Depending upon the environment, and the type of noise you're dealing with, pressure through the soft tissues below/behind your ear transmit through your skin and break down the small, inner ear bones causing hearing damage. Impulse noises like gunfire are the classic example of this. Even loud hammering can do the same thing. For really noisy environments it's not uncommon for both plugs and muffs to be necessary.Plugs reduce noise far better than muffs and aren't compromised by eyeglasses/safety glasses preventing a seal.
I have the same set. On my zero turn, I can barely hear the engine. I listen to music through wired ear buds at a normal level. Really like them.I have been using various Peltor (pre-3M) earmuffs for years and they always did OK. But recently I picked up a pair of the 3M Peltor X5A and I really, really like these. They are more comfortable than the old style, they seal to my head better (even when wearing glasses), and the noise reduction seems better. They are not cheap, but depending on your needs you can get the X2 for much less.
These are the best made. Been using the same pair for decades.I have the David Clark green ones...
I've been working in industry for 40+ years, and am still amazed at the number of people walking around with earplugs installed improperly, and complaining how they don't work.PSA: if you haven’t been impressed by foam earplugs, you almost certainly aren’t donning them correctly. Twist one slightly to reduce the diameter. Reach behind your head with your opposite arm and pull your ear back. This straightens your ear canal and the foam plug will easily insert to full depth. Within a few seconds the plug will expand and you will immediately notice extreme noise reduction. Rinse and repeat.
It really bugs me when I am near a loud machine and most people have their plugs half *** sitting in their ears so they can have conversations.I've been working in industry for 40+ years, and am still amazed at the number of people walking around with earplugs installed improperly, and complaining how they don't work.
And the pros with their plugs and muffs, or custom fitted plugs.
I have DC for aviation. Friend noted that they looked old (we bought them IIRC at OSH 1974) so he offered to upgrade them to active noise supression. DC is dead serious about supporting what they sell (sold).These are the best made. Been using the same pair for decades.
That is some good service.I have DC for aviation. Friend noted that they looked old (we bought them IIRC at OSH 1974...
I second this recommendation. Makes mowing the lawn a much better experience to be able to listen to music and protect what little is left of my hearing.
Does the active noise cancelling work with all types of machinery and power tools? I've heard that high frequency noises don't cancel as well.I have custom molded plugs that offer far better decibel reduction than the cheap foam plugs, but still wear muffs with active noise cancelling when I'm doing something really loud.
The kind I have does, but I'm not sure all will. I have something like half a dozen different pairs of noise cancelling headsets but only two pair I use regularly. One pair is/are Peltor TacticalPro and the other MSA Sordin Supreme Pros. I've used them around all kinds of noise sources without issue. I wouldn't be surprised if some of the less expensive versions don't cover everything.Does the active noise cancelling work with all types of machinery and power tools? I've heard that high frequency noises don't cancel as well.
Have rebuilt IIRC twice before, but that is what DC is all about - performance and support.That is some good service.
Oshkosh EAA fly-in I presume. Wonderful experience.
Look at the DC website.Have rebuilt IIRC twice before, but that is what DC is all about - performance and support.
Yeah, Air Venture as a side trip. We were actually in Appleton for first meeting of AYA.
disappointing.Look at the DC website.
Something to the effect of “effective immediately, hearing protector models are discontinued”.
Shoves wax and dirt in my ear hole and plugs them up.+1 for 3M Optime 105
+1 for foam earplugs
+1 for using them together in really loud environments, especially the range
Spend the money and get name brand (Bose) active noise cancelling muffs.
The ones I have are pure ****. Give me a headache wearing them. Would not trust them in an industrial setting.Spend the money and get name brand (Bose) active noise cancelling muffs.
I hated and had tons of pain and problems with my small ear canals and ear plugs. Howard leight laser lites changed that. I still have to reach over the head and grab my ear to put them in but they are so comfortable when I worked nights and slept in the day with small children at home I wore them to bed and 12 hours a shift so most of the day without any discomfort. They sure reduced loud noise better than my david clarks ear muffs. Some found it gross but its my ear, I lubed them up with a little spit to help inserting them.Some of the foamy plugs are challenging to use. I was commenting to the wife that the dirtier/waxier/oilier my ear canal was the better those plugs stuck. LOL The Howard Leight Laser Lite and Max 1 foam plugs for foamy types and Peltor X5A and H10A muffs here.
