I have this hand impact driver with 1/2 drive. The bit holder takes 5/16 inch hex bits. In the front, looking from the fat back end to the front drive end, counter close wise is marked L, and the other direction is marked R. When I push the tip in and turn it, there is a triangle that points either L or R. So just to confirm, I should put it to L to loosen bolts, right?
Also the target I need to deal with is Honda rotor holding screws. I heard that this is a JIS one. So I am wondering where to buy a JIS 5/6 hex bit that can be used on this hand impact driver. I expect it to be a more robust version than the common ones, right?
Finally, when you hit a hand impact driver, do you hit it with a brass hammer or a steel one? How heavy, 2LB, 3LB or other weight? I want to keep using the screws. So minimum or no damage is desired. Should I hit with a plastic hammer to begin with?
Thanks in advance! If you have any other suggestions, please send them my way!
