Ratchet Backdrag put to the test!
noid
No messing with strings, or scales, or other foolery; we've got ourselves a certified and calibrated tool!
Tool (Seekonk, Made in USA and Calibrated by Productivity Quality Inc):
Test subjects:
V1 Results.
Update with ClientGraphics measurements
Want to send me a ratchet(s) to test? PM me, i'll do it for free.
Ralf11
Great!
How accurate is it?
and... will it do ratcheting screwdrivers?
N
noid
Great!
How accurate is it?
Rated at +/- 3%
I don't have any ratcheting screwdrivers on hand to test, but could certainly do them.
dede2897234
Northern, Ohio
Test subjects:
Hi noid,
Very cool way of testing ratchet back drag!
Would you mind explaining how the testing tool works with the ratchet?
I see that the ratchet is placed underneath the testing tool.
If it is not too hard, would you mind taking a picture from the bottom ratchet attachment point to the tool?
Thanks,
Dave
KnurledNut
n/a
Since that Gray performed so poorly, send it to me and I’ll properly dispose of it.
:D
N
noid
Hi noid,
Thanks,
Dave
The tool has a female 1/4 end. To connect it to the ratchet I used a 3/8 socket to 1/4 male end. As you twist the top the beam clock wise or anti clockwise, it shows in inch ounces the force being applied.
:D
It pained me to see; its one of my favorite ratchets. The handle shape is worth the price of admission.
Didn't clientgraphics do a You Tube video on this?
Good find! Looks like he also used a seekonk, which isn't surprising considering its pretty well only Seekonk and a Japanese brand that make these (new anyways).
I've added his measurements to the cart.
Where are you located? I'd be curious to see an older craftsman USA and a HF Pittsburgh pro
Located in the Toronto area.
measuredtwice
USA
Did you use a Ko-ken ratchet to zero the instrument between measurements?? ;) :D
If the spring is too strong on some of the ratchets, sometimes you can replace the spring or shorten it.
N
noid
Cool, Noid!
The Kabo/Titan gearless is hard to beat!
Its all fun and games until the gearless ratchets show up.
To bad that they are always so gimmicky, either they are non reversible or non flex, not long enough, no QR or have huge heads.
Truly an under tapped market.
Kev442
Wi
It does show why people like their HP ratchets. They must use a very soft spring in them. I like the composites I have, but they can rust up internally really easy. Gotta keep them soaked in lube. Of course I tend to use them when brake fluid and other nasties are involved.
KnurledNut
n/a
Noid, a column stating Condition, New or Used, might be beneficial to your chart.
RoundedNut
driveway
This confirms my own experiences. The ubiquitous 72 tooth Taiwanese ratchets with the two pawls has the lowest drag, especially when they are lubed from the factory dry state. I still use them alongside other, "better" ratchets.
teagueo
Digging up an old thread due to my own research in low backdrag. Got this 3 oz-in torque screwdriver to measure the lower end of the ratchet backdrag spectrum - It's the lowest torque spec'd meter I was able to find. Only 4-5 ratchets were measurable within this range.
Snap-on FCF72
min 2.5 in-oz
max 3.0
72 teeth
Koken 3725ZS
min 1.85 in-oz
36 teeth
TRO Designs Superleggera
min 0.5 in-oz
max 0.7
36 teeth
Besides the Kokens, the 3/8" drive in a 1/4" body ratchets have some of the lowest backdrag I've found. The little Nepros is up there as well.
Video Proof:
teagueo
This little 3/8" drive in a 1/4" body Nepros (NBRC390FS) has very light backdrag as well.
Measured 1.5 to 1.7 oz-in of torque.
Karibu
Great! and as i live in Greece and yesterday i bought the new FACOM ratcheting(DUAL) screwdriver version, Facom Dual Ratcheting Screwdriver , which way can i test it (no access to Seekonk-but access to Facom's all torque testers). Any idea?
teagueo
Here are the back drag numbers from the most recent Project Farm test of 1/4" drive ratchets.
RatchetBack Drag Torque
(in-oz)
Back Drag
(grams)
Back Drag
(oz)
TRO designs0.74361.3
Koken2.05993.5
Wera2.421174.1
Milwaukee2.421174.1
Nepros3.141525.4
Husky3.411655.8
Proto3.471685.9
Mac3.511706.0
Snap On3.741816.4
GearWrench 1204.202037.2
Crescent4.322097.4
Der Erwachte4.922388.4
SATA5.002428.5
GearWrench 905.9528810.2
Hazet6.6832311.4
Duratech6.9233511.8
Icon8.4941114.5
Stahlwille8.7242214.9
He uses a 7/8 inch socket (~1.17" OD for Proto) and a scale measuring force in grams. It's not the most accurate way of checking back drag, but it gives a decent indicator for comparing the ratchets.
Torque = Radius x Force
In this case the radius is the socket OD divided by 2 which is the lever arm. Example for Snap On:
0.585 in x 6.4 oz = 3.74 in-oz
teagueo
@teagueo
I wonder who he got that cheap looking TRO ratchet from?
I tease, I tease...
Impressive stuff, man.
Lol. Thanks man. The Titanium and Carbon survived pretty well above sea level aye ⚓ ... With a cheater pipe on it and everything!
Speaking of @KnurledNut, we're scrapping the carbon fiber handle and going to full Titanium with an aggressively knurled grip.
Eliminates a few parts (and a bonding process) and will drop the price significantly.
KnurledNut
n/a
Full titanium version? I need this in my life!
Madjik Man
Can’t wait.
My wallet hates you though.
teagueo
Not to hijack this back drag thread, but we've been looking at a few design changes after the Project Farm test. The switch effort was one of them, but it wasn't improved before the test...
Yes, different coatings (colors) coming soon too 😁
Bradc1989
Middle tn
Is the op still around? I’d be curious where my 90t proto and 90t sk fall as they’re opposite ends of the spectrum compared to each other,
where can I get more info on the titanium ratchet? that would be the ultimate one up with the shop, and I’m just that kind of guy
teagueo
Not sure if it's kosher to post a link here, but for more info:
