Intro Machining Tools
Alberta, Canada
Hi all,
I'm developing the machinist side of my highschool program and am wondering which good entry level metal lathe (can be small / counter top) and manual mill you'd recommend. Thanks!
txvwnut
Bedford, Texas
I’ve been lathe shopping lately and have narrowed my choices to Precision Matthews. Good pricing and all of their lathes use an inch thread pitch in the lead screws. The lathe I have at work is metric thread pitch and really messes me up as the lathe manufacturer did not convert the dials.
T
Alberta, Canada
Thanks so much for this! Going to look into it right now!
G-ManBart
Definitely take a look at Precision Matthews. All of my lathes (7 so far) have been vintage U.S. machines, but I've told my wife that my retirement present is a PM 1660TL which is their "ultra precision" line. The few times I've seen someone have a problem with a PM machine the company has gone out of their way to resolve the issue.
There are a couple of other companies having similar machines imported (cheaper lines from China and better lines from Taiwan) but PM tends to spec theirs a bit better. They are based out of Pittsburgh and get nothing but good reviews from what I've seen.
Cruzan80
Denver, CO
Subscribing, as I may be looking to add the same. Specifically more into smaller mills, including CNC. Biggest issue will be space and how to get a class' worth of access.
G-ManBart
If you haven't done so, check out the Hobby Machinist forum. It has a sponsored section for Precision Matthews, but also has sections dedicated to home CNC as well as smaller mills. The people there are incredibly helpful, encourage beginner questions and you really never see any rude behavior....very well moderated (much like here).
On the flip side, I won't say to avoid the Practical Machinist forum, but that place is a minefield for home shop people. No discussion of hobby machines or most less expensive imported machines is allowed. To top it off, you can be as rude as you want there and even the administrators take part...nobody seems to mind personal attacks. I use it largely for reference purposes when I want to research something, but rarely post.
no704
Not sure on current times, but Hass used to do quite a bit to help out schools.
RoninB4
Under My House
Your budget will largely dictate what your shopping list will be. It would be good to estimate the size of the work envelope you expect to use. No point getting a 12 foot lathe when all you'll do is small sized work pieces. No recommendations for brands, either they're too expensive or just not very well made. Too large kills the budget, too small is a toy making other toys. If all the program is teaching is the fundamentals and calculations then I don't guess it really matters if the machine is good enough for teaching efficient metal removal rates. It really is about what the syllabus/curriculum goals are. I would offer one piece of advice, expect all machines to be crashed at some point. Safety is another huge topic, expect a serious injury to occur at some point.
Cruzan80
Denver, CO
For mine at least, thinking smaller sizes. Right now, they have some small wood lathes they turn pens and smaller bowls on. The issue with larger machinery (even 12x36 lathes) is both price and footprint, to get the quantity I would need. Along with maintenance to keep them running. Smaller ones making "toys" still teaches the fundamentals, even if they can't do it perfectly the same on a larger machine. Also cost of materials adds up as well, as we have to source all of this from "known good" materials, no mystery metal or cut-offs usually due to the issues with trying to pay for them using Tax-Exempt thru a bookkeeper.
RoninB4
Under My House
-It really is a balancing act to get capability and stay within a budget. Used machinery is a better buy but that's usually not possible for companies and school programs. Nothing wrong with getting smaller machinery for teaching fundamentals, it just severely limits what is possible to do. Small machines are also somewhat difficult to use unless you have tiny hands. Larger machinery, while being more capable, has a greater risk of severe injury. Maintenance is really a non-issue, keep it clean, lightly oil the ways, and follow manufacturers instructions for motor/spindle/carriage/table lubrication.
A number of motors that come with machinery that comes directly from China have a disturbing tendency to burn up for no real good reason other than they're poorly made. Some fry, others will last for several years. Machinery that uses plastic gears in the spindle drive or carriage feed may explode for no reason. I had a small mill left after selling all my industrial grade machinery and I blew up 2-3 plastic gears in very light cuts. That was over 20 years ago, don't know if that's still common. Companies like Precision Matthews supposedly spec some components to higher quality but I can't confirm this. No other experience with hobby grade, light duty machinery.
Material shouldn't be a problem either, there's several places to order from so no "mystery metal" would be involved. Setting down the curriculum per the machinery size would be the greater task. With metal working machinery you get what you pay for most of the time. The expectations/goals for passing the class really need to be defined. Not an easy task teaching goofy high school children either, I wish you good luck and applaud you for doing so.
cannuck
Rural SK
of two minds on this subject: to teach in my own shop (to myself, children, etc.) I have a Chinese mini-lathe and a 40 year old Taiwanese 14 x 40 that weighs 800 lbs. The little one is so week a big screw-up just stalls the chuck. The 14" machine has 3 HP and that is enough to break a $200 parting off tool in a hurry if you try to take too big a bite (flexibility of tool post). My new shop lathe is a 15 x 50 VFD Cholchester at 6500 lbs. and it will run circles around the other tools....but not so sure learning on something with no vices is quite as effective.
RoninB4
Under My House
-Metal working in inherently dangerous, no two ways about it. Peeling off stringy chips in the lathe can be considered a mass of whirling razor blades. A multi HP motor can easily break fingers or drag you into the rotating mass. Machinery doesn't care, it does what you set it to do whether it's right or wrong. Milling cutters have sharp edges that will easily go through flesh/bone with less effort than the metal you're cutting. Power feed doesn't care if your hand/finger is in the way, it will crush/cut whatever is between the spindle and the vise. It will drive itself into the chuck until either the motor stalls or the lead screw breaks. Exploding cutters that send shrapnel into anybody nearby is of no concern, the machine doesn't care.
This is why safe working habits are pushed, and should be, in almost every discussion of metal working. Each machine has a built in danger factor and each operation you use it for has a potentially hazardous consequence. Turning/facing can create a bird nest of rotating razor blades if a chip breaker isn't on the cutting bit. Cut-off blades that are hung out too far, and/or if there's excessive play in the cross feed screw, can easily snap off. Work that's poorly held in the chuck can be thrown out when tools break. How would you like to catch 2 lbs. of metal in the face traveling at velocity? Serious injury that can be life altering. Milling machines have a danger factor as well. Exploding end mills (it happens) from excessive feed rates, poor clamping in the vise that will lift the work out of the jaws, or work-hardened material the end mill won't cut so it just explodes with the feed pressure. Grinders are even more dangerous. Lathe and mill accidents often give a brief moment where you realize something is about to go wrong. Grinders often don't give you time to react. A company down the street had a guy that was a jig grinder operator. He came in for morning shift, started the machine to warm it to operating temperature. This was SOP for him every morning. The mounted wheel had a micro-fracture in it nobody detected. As the mounted wheel spun up to 20,000 RPM the 1/2 inch wheel exploded, throwing a small chunk into his chest. He died before he hit the floor and hadn't finished his first cup of coffee.
There's a lot of safe working habits to follow. Stand out of the way of the "throw" when using a lathe. DO NOT attempt to pull strings of chips out of the lathe while it's running. Listen for a change in sound that may mean trouble is developing. Does the chip look like it should? Why not? Is the work properly supported? If holding the work with a live/dead center in the tail stock, is the cutting force pushing the work back into the chuck (no longer supported by the tail stock)? Are you attempting to use the cut-off blade in one shot? It better have everything right or it can easily break off, better to use a "peck" cycle. Is everything in the mill locked down securely? If the feed rate is too high for that machine (excessive slop in the gibs or lead screw) it can explode the end mill. Is there's a chip guard deflecting hot chips to protect the operator? Which direction will metal exit the machine? Are you standing in the flight path?
It's a long list of potentially dangerous circumstances and I apologize for being long winded with this post but the machine shop is no place to dance with disaster. When learning, read all you can about what can go wrong because it will. It's not "if" it's "when" it will go wrong. When teaching others, especially children, they need to be closely watched for habits that may put them in danger because they simply don't know. Safe work habits sound like a lecture unless the consequences are explained. I've seen a lot of industrial accidents over the years and it makes me cringe to think what can happen as I try to encourage others to pursue metal working. I don't want my encouragement to result in an accident/injury for someone.
Be safe, end of lecture.
Aaron_W
Maybe a mix of sizes? None of the affordable lathes under 12" include a quick change gear box. PMs 1228 is the smallest, cheapest ($4300) available with a QCGB. Their 10 and 11" lathes do have more features than the average small lathe.
For really small work likes pens, you might consider some Sherline or Taig lathes. Both are made in USA and quite capable for their size. Cost wise you could get several for the price of one PM1022. Both can be set up for CNC as well.
RoninB4
Under My House
-Perhaps, tough call to make. A lot will depend upon what the program wants to teach. If it's CNC programming of G and M codes then size isn't really important, one of those micro machines in a box (educational machines) will do fine. If the program seeks to produce graduates somewhat ready for employment in a machine shop after high school then that's a different story.
Perhaps a mix of classes? Tiny micro machines for G/M programming and larger machines for larger projects? Were I wanting to make watches or pens the Taig and Sherline products seem ok. My bias tends to regard those as artisan craftwork, nothing wrong with that either. Sometimes wished I was making things light enough not to damage my foot when dropped.
Most machining is performed on larger pieces with a great deal more mass and if your only experience is with a micro machine I'd have doubts hiring a kid for industrial grade machining. Starting a machine/fabricating shop is expensive and I feel for anybody attempting to do this with dreams larger than the budget will allow.
A quick-change gearbox is quite useful and expensive, changing actual gears is a PITA. Mills that have a quill and quill feed are better but more expensive than the crappy round column mills. A DRO is important on either machine.....and adds expense. Having CNC controls is very important in modern machine shops, also adds a lot more expense and potential maintenance issues. All that remains of the once great machine tool industry is the very expensive and the rather poorly made machinery.
Buying new presents a huge obstacle for the budget, getting local factories involved in funding (new crop of well trained graduates to choose from) can benefit both parties. "Hire the micro-machine trained kid? Next applicant please". This is why buying used is a better choice and, unfortunately, not an option for many institutions and businesses. My 5,000 lb. jig borer was $300,000 when new and lived for 20 years in a climate controlled room. I got it for $1,500 with a full cabinet of tooling and a Heidenhain DRO when the depreciation schedule ran out. It was almost embarrassing when they accepted my lowball offer. No way I could have afforded that when new. It still had 80% flaking on the columns.
I don't know what the answer should be for an institutional start-up program but a realistic look at the goals, curriculum, and budget sources is crucial before anything else is discussed. CNC programming can be done in a virtual environment via the graphics in CAM/CAD software (educational versions). Shop ready students need shop ready machinery. Just an opinion.
Cruzan80
Denver, CO
I wonder if we are approaching this with different goals. Even though I am CTE (Career Technical) endorsed in Colorado, I don't expect that my seniors will be able to graduate and immediately get a job in machine shop, at least as an operator. Apprentice-level is the target we are aiming for, for all of our skills. There are a few Vo-Tech schools with 1-2yr programs, which would fill the experience gap I ("think") Ronin is concerned about.
This will be my first year at the school I am going to, and I am also somewhat concerned with the "artisan craftwork" style of the current wood curriculum. However, keep them interested and involved is a key priority, and their "precision" experience is somewhat lacking. The "artsy" lends itself to a "Pin A only needs to fit in Slot B", not that Pin A or Slot B need to match an external dimension for repeatability (to start). All of this is with manual wood power tools, freehand currently.
RoninB4
Under My House
-Perhaps so, I was attempting to address what the OP of this thread was enquiring about. Metal working machinery is all I'm (somewhat) qualified to offer an opinion on. I do woodworking as a hobby, mostly by hand tools, using power tools when required. I've built several tables and a 400 lb. oak workbench (no metal fasteners) but that hardly qualifies me to comment on an institutional/educational woodworking program.
"Apprentice-level is the target we are aiming for, for all of our skills."
Apprentice programs in the skilled trades have been in decline/disuse for decades, at least in the Rust Belt they have been. Apprentice programs in the Midwest have largely been tied to or sponsored by unions and/or local manufacturers. Can't speak for your area. I wouldn't know how to keep a teenager interested/involved in anything unless they wanted to. My brief involvement helping at a local Vo-Tech introduced me to about 25 students in their late teens or early 20's. Only about 4-5 of them showed any promise, the rest didn't really regard the training as something they would have to do for the rest of their lives. I might have been the same right out of high school.
Any concern I expressed was largely about safety when power tools were involved, one accident can be life changing regardless of the motor HP. As for artisan craftwork vs. industrial fabrication, form vs. function is a lengthy topic and both have a place. I feel the educator with real world experience has a greater impact on the students than the machinery. Learning textbook exercises is ok but learning to work with what you don't have encourages creativity and innovation. There is no substitute for personal experience stories. I've held a teaching position on several occasions on different subjects and teaching is a skill in itself. I wish any of you approaching or involved with teaching good luck. For good and bad, you are shaping the future in every class.
Cruzan80
Denver, CO
Ronin, I was also taking about "adding" metalworking. Currently, they have woodworking as part of the curriculum. Out here in CO, seems like there is a bit more than when I lived back east (Pittsburgh, so solidly rust-belt).
I was more thinking of the fact that what I am looking to add is the very basics to start, whereas you seemed to be talking "hire-able" when finished with my program. My point was that at the level I am going to be teaching it at, I would expect another level between my expectations and yours. This is for those kids who have done 3D design/printing, woodworking, and then want the next level.
Just trying to clarify. Everything you have said is good points, just the scalability is the issue for the school environment, especially for HS class sizes vs Vo-Tech post secondary.
Well aware of the safety, have a 12x36 lathe, 8" shaper and BP knee mill in my home shop. If I need larger, a buddy has a 16x60 and 14x48 lathe, an 18" shaper and a larger mill (CAT 40/50 tooling, forget which).
Hopefully didn't drive the OP too far off topic. Meant to post something similar, them saw his and jumped on.
Aaron_W
As a high school program I'm looking at it more as an introduction to machining / metalworking than a vocational get hired out of school thing. My experience with high school metal shop was in the 80s and as I recall we had 4-6 small/medium size lathes, probably 10" but maybe 12-13".
Looking at the costs of machines, (just going with PM for simplicity)
PM 1022 (10x22" change gear lathe) $2900
PM1228 (12x28" with QCGB) $4400
PM1236 (12x36" with QCGB) $5000
Sherline 4400 (3.5x17") with C accessory kit (so nicely tooled) $1350
So you could get almost 2 1022s for the price of a 12x36 and 3 Sherline for the price of a 1022. Say a $20,000 budget, you could have 4 12x36, or 6 10x22 change gear, or a mix of one 12x36 for advanced work, 4 10x22 for regular work and 4 Sherline for small work and brand new students. A Sherline can hurt you, but more break a finger or give you a nasty cut, unlike a 12x36 which is quite capable of killing or maiming an inexperienced or inattentive operator.
Sherline is small, but it teaches basic skills just like a big lathe, and they don't have the quality issues of the Chinese mini-lathes. Great customer support, and good quality control so rarely need the "finishing" common with the imports.
Just a thought to have more students working within a budget and it would help them learn to choose the right machine for a job.
RoninB4
Under My House
-You're correct in me having a different level of proficiency/capability for the class curriculum in mind. Perhaps it's because I was in the trade for so long and know how much they need to learn. My only reference is from my high school shop programs in Detroit during the early 70's. Internal/external threading (single point on a lathe), gear cutting, and milling were all part of what could be learned if you were a student with potential. Cut-away examples were on display that could have been duplicated from an automobile manual transmission. You were almost ready to go to work if you paid attention and applied yourself during those classes.
Things are different now....
The 3D design classes are good, I earned a living from 3D mechanical design for the last 16 years and feel it's an essential tool in manufacturing today. As for your students, you probably know what's best for them more than I would. I may also be having a knee-jerk reaction to the youth of today not knowing how to do much of anything with their hands because they never had the opportunity to learn. I don't advocate anybody seek a career in the machine shop, it's not a glamorous or highly paid vocation. But I feel it's good to at least have a basic understanding of how things are made. Perhaps it's better having secondary Vo-Tech schools provide training for those truly interested. High school students have no idea what they want to do with their lives.
I don't suppose I have much to add to this thread other than my applause for those of you providing that opportunity to learn and my wish for your success in that endeavor.
RoninB4
Under My House
-Valid point to make about engaging more bodies, waiting for a machine to be open impedes the work flow. This also tends to dampen the enthusiasm of youth and provide ample time to disengage from the project.
Contact manufacturers. Many have Very different prices and programs for schools.
-Very good point to bring up. Some even have educational versions of their own products the same as software companies do.
