Hello,
Last weekend I prepped my garage floor for epoxy-coat by diamond grinding it. I had one thin but long crack across the floor which I wanted to fill. I used DAP 3.0 Self-Leveling Concrete & Masonry High Performance Sealant, which says "paintable" on the package. Unfortunately, as I was smoothing the sealant, I spilled/smeared some of it on the concrete about 1" on either side of the crack about 6-8 feet long.
http://www.dap.com/product_details.aspx?BrandID=190&SubcatID=27
Now I'm worried that the epoxy will not adhere to this area. Do you think that I Should be concerned?
If so, any suggestions on how to remove the sealant and re-prep this area?
I also filled the cracks at the bottom of my expansion joints with a thin bead of the same stuff.
Thanks in advance!
Thanks in advance!
