Torque wrench stored with a few pounds set... chances it's usable?
67carl
California
I took out my torque wrench, which hasn't been used in a few years, to find I put it away without resetting it to zero. I think it was on 10lbs. *******. I don't have a calibration tool or another wrench to test it. I will ask friends who may have one and see, but in the meantime, what do you think the odds are it is off? It's an inexpensive Pittsburg click wrench, so I wouldn't be out a lot of $.
T45
At 5x that thing is only good 30-150 range, so spending some time at 10 lbs isn't going to kill it, instantly. The bigger problem is letting it sit for years, which increases the risk it could take a set. also the grease could dry...you never really know. Definitely work (in) the mechanism before testing it. Friendly reminder time--This is why theres a good rationale for keeping around a few dials and split-beams and older style wrenches.
tamaraw
That is basically the cheapest torque wrench you can buy and probably wasn't too accurate to begin with. Most decent mechanical wrenches are only rated for accuracy between full scale and 20% of full scale. (In your example, 30-150 lb⋅ft)
With it being set so low, I probably wouldn't worry about it too much, I just wouldn't use it on anything critical.
Kuma601
Cali
Likely negligible. Many applications have a range that are acceptable and for less critical applications not to worry if off a few percentage.
Komet
WA
It's fine. As mentioned, it's supposed to be returned to the minimum torque spec.
uart
Australia
Most directions say to return to the minimum spec, not to zero.
If it was set at 10 pounds then you're good to go.
^ This.
The specs on that wrench are 10 to 150 ft.lbs. At 10 the spring will be barely even compressed, so no chance of causing any issues. I've got one similar and the spring doesn't even engage below about 7 (like when you rotate the handle there's no resistance below 7) so that's where I usually store mine, but at 10 the amount of strain on the spring would be negligible.
KnurledNut
n/a
If you have an accurate bathroom scale, you can weigh an object within range weight, hang it from your torque wrench, and figure the math to check it.
It's a HF torque wrench. It may never have been completely accurate.
bb29510
mine is sitting on the shelf with 450 lbs on it, been there 30 years. Im not worry a bit
