I want some decent crimp terminals for general use. Rings, spades, quick-disconnect, splices, that sort of stuff, not connector pins. 10 awg would be the biggest use, 18 or 20 the low end. Basically, the red, blue, and yellow kits found in autoparts stores would cover my needs, except those are garbage. I don't use them very often, but when I do, I need them now, and it gets something done today, instead of, well, sometime later. Insulated preferred, but not a deal breaker if I have to shrink tube them. Probably should get a decent crimper to go with it, so recommendations for that accepted, as well. Use is mostly "random stuff", not automotive. (my last remembered uses were fixing an AC wiring harness, and replacing the cord in a power tool, which is pretty typical.)
