Hi, all.
Recently moved into our home and I'm looking for ideas to help keep the garage a bit cooler in the heat of summer.
The garage door (16') faces NW and there is a room "behind" the garage that would block the direct sun. To the South / SE of that room is a lot of trees but there is plenty of at least filtered sunlight that hits the back wall of the home. Direct sun hits the roof. Above that room and the garage is attic space. Over the last few weeks, daily temps have been anywhere from about 75 to 90 (ish) and the garage temp is generally at least 5-10 degrees above the outside temp but it does seem to peak a little over 90 degrees. This is with no cars in the garage at all because we are still in the process of moving in and all of our "stuff" is in the garage in boxes while we work through it.
In the very near future, one of the cars that will be in the garage is my V8 convertible which gives off a LOT of heat after being driven and I'm looking for any ideas on how to possibly provide some sort of venting for this space to keep the temp from getting so high. Anyone have any thoughts on a simple, easy way of venting the space? Pic attached shows the orientation of the property for reference. There is a window on the side wall that faces NE.
